It's been awhile! (Sorry, folks. Life, & maybe some laziness on the posting front.)
This project has been coming along.
Rear Brakes.
I pulled and rebuilt the rear master and caliper - and connected them with a new brake line. I now have reliable stopping action up front and out back. I could swear that I took more photos, but I don't know what happened.
Those in the know know that extracting the pistons at the rear can be tricky, as the body splits in a way that prevents the use of hydraulics for full extraction. This rear caliper gave up its pistons without too much difficulty, as one came free without real persuasion. The other came free with the use of a vice and a little elbow grease.
At this point, it's all rebuilt, mounted, etc - with the rear wheel back on, gear oil loaded up, etc.
Carb Rack.
Umm. Frustrated.
The rack itself looked good. It was partly disassembled back around '85, but all the bits were neatly stored in little "Swiss Miss" type containers. Slides/caps were kept with their matched mate. I pulled all the jets, cleaned up the body to address the clear coat that was peeling, and put on the Randakk's o-ring set. (I did NOT split the rack, soak it all in a bath, etc.)
In the process - argh! - I broke off one of the float mount posts (#4 carb). Maybe I should revise that statement to deflect responsibility: "In the process, one of the float mount posts broke off." Nah. I know I did it. Pisser.
Back at Randakk's, I bought the fancy "deluxe" billet aluminum float post repair gizmo - nearly $40, so that's a pricey mistake.
I hacked off the remaining post, filed things down nice and nice, cleaned the rack, and reassembled.
I've done GL carbs a few (more than a few) times, so I wasn't too worried about getting it back together. Clean jets, all orifices clear, new o-rings, etc. The rack looks darned good, actually. The caps and even the bowls are shiny, as are the the intakes. (Something about climate-controlled, no-UV storage for 40 years.)
Last night, I hooked up a fuel source, popped in a battery, and fired her up. YES!
Then, NOOOOOooooooo.
I'm getting fuel in the plenum. It was coming from the left bank, and it looked like it was flooding in from #4. Fuel off - fast. Rag in plenum to mop up. Run the bike to drop fuel level in bowls. #4 is also leaking around the bowl seal, a new Randakk's unit.
Pull the rack.
Good news - My screws for the #4 bowl were nowhere near tight enough, so that's a mechanic's error.
I got back into #4. I pulled the float, the deluxe billet kit, etc. I gave it all the stink eye. Honestly, the part seems to sit nicely, with no obvious way the unit might prevent the needle valve from sealing. The float needle valve looks good on close inspection.
My float measurement was a bit off, but it was off in a way that should prevent the bowl from filling to the spec - not the opposite way. I fixed all that, measured thrice, etc.
Reinstall this AM
Bike fires up soon after bowls fill, so good news.
And no leakage from #4 bowl.
Then I get the flooding in the plenum - again. I swear it seems to be coming in from the left rear of the plenum (above #4). Maybe the bike isn't quite level? (On center stand, in solid-floor shed that isn't leaning/sagging.)
Next Steps, me thinks
- Pull the rack again, check inside #2. Maybe the float is stuck down and the valve is in the open position. And maybe it's just too hard to discern flooding from #2 v #4. (I maybe rushed to think it's in #4 just because I was getting spillage from the loose bowl screws.
- I'm also starting to think that perhaps I have a deteriorated o-ring where the #4 carb mates to the plenum. If so, I guess I'll do the full monty on the rack. I have the kit. It's only time - and the reality of 62 linkages, 14 springs, and a whole lot of room for error.
In the Stable and Ridable
1978 CB550K - son's cafe
Sold
