Whiskerfish wrote: ↑Fri Jun 21, 2024 6:08 pm
Was working on the 1200 today and noticed that there is something sandwiched between the rotors and the wheel hub. Looks like a piece of thick paper. Parts book calls it SHIM, DAMPING but this may not be the oem part on here.
Damping
I know my 81 CBX had those but they literally fell apart when I had the vented disc’s off for whatever reason which was before breakfast so I don’t remember why I had it apart, but those shims were not available so I didn’t replace them, I didn’t figure they really could do much anyway eh ?
So now for the past 20 or so years its had a low speed harmonics/squeal when coming to a stop, not loud but there. I’ve tried 3 different pads on it, even lightly sanded the rotor faces to break the glaze and then just figured it was just a thing with those rotors.
But now I’m kinda thinking maybe I need to put some back in, I dunno ! Or maybe I used dampening shims instead of damping shims Sorry Bob, sometimes ya just gotta laugh !
Thanks for the input. I finally started to clean the 83 front wheel and sure enough there is a gasket like material stuck to the wheel. Couldnt get it off without destroying it so I picked up some gasket material on Amazon. When I get it back together I'll check the position of the caliper on the rotor and see what it looks like. Wonder if I do run it should I re torque the rotor after running some miles.
Anyway I'm a long way from that in my build. Just trying to get all the pieces and parts lined up.
Not sure on the 1100 but I think the 1000 rotor nuts are supposed to be a one time use IIRC. Most of us just give them a good squeeze with pliers to make sure there is sufficient "run on" torque. They are a self locking style nut. Torques for the 1000 are here: viewtopic.php?t=41020#p424090
should be very close to the 1100.
Heck I have reused them a lot. Lock tight is your friend
-Rodger- all it takes for evil to prosper is the want of a few good men to do nothing-Edmund Burke The question is not how much time do you have, it is what you do with the time that you haveGandalf "One of the greatest dignities of humankind is that each successive generation is invested in the welfare of each new generation." Fred Rodgers "it takes 10,000 hours to become an expert" ancient saying
Hey guys, its been awhile but I finally took my first ride on the 82. In response to the spacer material between the wheels and brake rotors, I did cut some .75 mm gasket disks and used them when bolting on the rotors. The brake calipers lined up perfectly in the center of the disk. I've only done 10 miles (still need a tag) but everything seems ok.
I haven't been posting but thanks for all the unknowing help the forum has provided and thanks to Robin for doing my carbs. As soon as I get a tag ill let everyone know how it is running.
What I did:
Stripped and cleaned, painted frame, motor, fuel tank.
Rebuilt Front end with progressive springs.
Rebuilt brake calipers with SS lines.
83 wheels, rotors resurfaced.
Carbs rebuilt by Robin.
New fuel pump.
All new hoses, cables and hardware.
New timing belt.
Aluminum radiator, new thermostat, hoses.
Polished aluminium engine pieces.
Bunch of other stuff.
'13 Honda NC700sa … TNG
