Spokes vs. mags
- Joker
In my head is the "feel" of the perfect bike for me and the parts that go into it. I've had alot of nice bikes and bikes that were good for me. I have yet to assemble all the "perfect" parts on the same bike, though!
In my head, though, are laced wheels. I use them and maintain my bike such that it hasn't been an issue.
I have allergies to mags, billet, tassles, bells, bright colors and brand names on my bikes.
I forgive the GL1200 for its mag wheels and continue to lust.
1976 GL1000
[img]http://s351.photobucket.com/albums/q473/YoungFamilyPics/Louisiana/E3bikepics/th_img428.jpg[/img][img]http://s9.photobucket.com/albums/a89/bayoubikebruiser/th_img215.jpg[/img]
"Tattoos are cool." [img]http://www.dualsportridersoflouisiana.com/forums/images/smilies/4223726244319a5ae79351.gif[/img] "Yeah, I wish I was born with one.
http://s9.photobucket.com/albums/a89/bayoubikebruiser/76Goldwing/
Or cast wheelmrflamewerks wrote:Alloy wheel.Ebola wrote:Okay, since nobody has wheels on their bike made out of Magnesium can we progress to the more common use of the word "mag" to mean what we all think it means unless Bob has an actual term that we can use in it's place?
But Comstars are what Scott was talking about at the beginning of this thread. Comstars are a built up wheel so they are neither cast nor magnesium.
Arrrrgh!!!!!
Comstars aren't mags, with or without rivets. They aren't cast either. Go look at one and you will see what I mean. Until then you won't be able to get it.
Comstars are built up wheels with cast alloy rims & hubs and pressed steel spokes - they are NOT "mags" because they contain no MAGNESIUM.
Comstars were a superior design because they flex like wire spoked wheels but since their rims have no spoke holes they can be used with tubeless tires.
The flexing was an important feature because cracked spokes were common in early cast wheels that other manufacturers were using. Honda didn't use the cheaper (&, IMHO, less attractive) cast wheels until they were sure they could get ones that wouldn't crack.
ElPiloto
- cyclepsycho
O.K., I just replaced all the rivets in my Comstars with Magnesium.Sidecar Bob wrote:Arrrrgh!!!!!
Whatcha gonna do now?
Being evil is my only source of entertainment this time of year.....
- mrflamewerks
Comnesium?cyclepsycho wrote:O.K., I just replaced all the rivets in my Comstars with Magnesium.Sidecar Bob wrote:Arrrrgh!!!!!
The difference between Genius and Stupidity is that Genius has its limits.
> Unknown
He who sacrifices freedom for security deserves neither.
>B. Franklin
78 GL1000 Pending Resurrection
78 GL1000 Naked (gone to pieces)
83 GL1100 Interstate
99 GL1500CF Valkyrie Interstate (Gone to the Darkside)
99 GL1500C Valkyrie Standard (Gone to the Darkside)
> Unknown
>B. Franklin
- detdrbuzzard
spokes vs mags
ever have a spoke break ? probally not, i have only going 35-40mph. it locked the rear wheel no damage to me or the bike, undies were ok too
'75cb750, '79cb750 super K, '79cb750f,
'99 ST1100,'93gl1500se, '70 ct70H, '05sunL70
'06 ST1300a
... william
'06 ST1300a
... william
From you I would believe that........cyclepsycho wrote:O.K., I just replaced all the rivets in my Comstars with Magnesium.
I thought the rear suspension of my GL1000 sidecar outfit was squeaking so I leaned across the bike to have a closer look. I discovered 6 broken spokes! I called a buddy that worked for a Honda dealer to see if he could get me a few spokes and he told me that they were only available in sets and I would need to have a pro lace it up. He recommended I phone around to all the wreckers to see if I could find a COmstar instead.detdrbuzzard wrote:ever have a spoke break ?
- confish86
- My Album: http://www.ngwclub.com/gallery/v/wingmans/album169/
I think it would be better if you just said non spoke wheels , so nobody gets there panties in a bunch about it.Ebola wrote:Mags it is.
IBA # 47424 (yahoo)
76 GL1000 (Naked)
78 GL1000 (dead title , but got a 79 frame for it)
2012 Kawasaki Concours (LD bike)
Ban low performance bikes....NOT high performance riders!
76 GL1000 (Naked)
But they all have spokes. Comstars have pressed steel spokes and cast wheels have spokes cast into them.confish86 wrote:I think it would be better if you just said non spoke wheels
Now, disc wheels are another matter....
BTW: Wire spoked wheels work by tension - the spokes on the top bear the weight.
Cast, Comstar and even wooden wagon wheels (& their derivatives that were used on early motor vehicles) work in compression - the spokes on the bottom bear the weight.
- hmratbam
I've heard that compression of a spinal disc is a bad thing. They used to make those swing thingies that hung you upside down to put tension on your spine,s'posed to be a good thing?
My Album
84 Standard ongoing project
My Album
- Joker
Arrrrgh! They're not "swing thingies", they're Swang Thangs. Swing thingies work by tenspression. Swang Thangs work by gremlins in the material acting in past tense to clean and whiten the tolerances which have to be set to "stun".hmratbam wrote:I've heard that compression of a spinal disc is a bad thing. They used to make those swing thingies that hung you upside down to put tension on your spine,s'posed to be a good thing?
RTFM, man.
1976 GL1000
