Guess you missed this previous post, Chef.the chef wrote:Very very nice!
What color is it going to be,,,,,,,,, BLACK?
http://www.ngwclub.com/forum/viewtopic. ... c&start=90
In a word. No!Neil wrote:That front wheel looks really good. Are you happy with the stainless brake lines you have
Do you reckon a centre punch, small hammer and a few hours might do the trick?ElPiloto wrote:I have used knurling on brand new pistons. The knurled area holds oil and lubricates the pistons better.
Knurling was very popular in the 30s, 40s and 50s when everything was repaired, not discarded.
There are 2 ways to knurl a piston. The first is to use a knurling machine. You clamped the piston, upside down, and tightened the knurling wheels and twisted the piston back and forth by hand until the knurl was finished. Needless to say, these machines are very rare now.
The modern way is the chuck the pistons up in a lathe and mount the knurling wheel in the tool holder. Then you can move the piston back and forth by hand until the knurl is done on both sides of the piston.
If there is an auto repair shop that has been around for 50 or 60 years, they will probably be able to do it. Most young mechanics have never heard of knurling.
ElPiloto wrote:I was able to reuse the pistons on a Yamaha 2 stroke by using a punch and hammer. Just don't hit the punch too hard. A worn or rounded off punch works really well. If you use a spring loaded automatic punch, all the dimples will be the same.
