GL1100 with throttle bodies (Fuel Injection)
AstroWing
Re: GL1100 with throttle bodies (Fuel Injection)
#151
Post by AstroWing »
I called the company (14.7) and after a short conversation I ordered one O2 controller $75. So, between ICB and Socrace I have gone from a near $400 solution to $190 to $75 just from asking a couple of questions. This is a great forum. Socrace and Irish Car Bomb, I will definitely buy the beer or ICB's if we are ever in the same bar.
_________________
Have lots of bikes... need one more.
Report private message Delete message
socrace
#152
Post by socrace »
The Spartan 2 from 14point7.com is a good deal, although I think the cost is actually $125 when a sensor is included.
Innovate has been around longer, but probably not worth $65 more, especially as it uses an older design and sensor type.
AstroWing
#153
Post by AstroWing »
Hello Socrace,
Yes, the selling point for me to decide on the Spartan 2 was it works with the latest Bosch O2 sensor. These are the same O2's as all the race teams in my area use on their cars. I am able to pick these up for free as they mileage them out when there is still much life left in them. So I only ordered one, 14point7 bare controller for about $ 75.00.
Before you and ICB started advising me, the only advice I had was to get two Innovative controllers with two of their O2 sensors.
I am looking at your wiring diagram and trying to see how it will work with my Chevy LS coils. (built in drivers) and no cam sensor. (wasted spark)
Thank you.
socrace
#154
Post by socrace »
My current wiring diagram is different, but this previous one is probably closest to what you're looking for.
This one uses 2 fuel injector channels, 2 ignition channels and a single crank position sensor, which I think is what your build is using:
AstroWing
#155
Post by AstroWing »
Hello Socrace,
Thank you this wiring diagram it is exactly what I needed. I'm not sure if I understand pin 87
My day job has me pretty busy for awhile. I hope to get back on this project soon.
socrace
#156
Post by socrace »
You can use TunerStudio to tell Microsquirt to use this pin to increase engine idle rpm when first started and when cold.
Not really necessary but nice to have.
Mine is set up to use a Ford/Bosch type IAC unit. It feeds air to a small 3/8" manifold, then 3/8 lines to each throttle.
AstroWing
#157
Post by AstroWing »
Sorry I should have figured that out. Fidle - fast idle.
I don't plan to use an electric solenoid one. I may put a bigger knob that I can quickly turn up when the engine is warming up. My idle stop screw is easy to get to if the bike turns out to be cold blooded.
Thank you
thunderchild
My Album: http://www.ngwclub.com/gallery/v/wingmans/thunderchild/
#158
Post by thunderchild »
Wow. Nice work! Just stumble on this thread from facebook. A little over my head but a great read. Looking forward to to see the end results. action1
"The trouble with the world is not that people know so little,
but that they know so many things that ain't so." -- Mark Twain
Current bikes:
76 CAFE GL1000
76 YELLOW GL1000
76 LTD GL1000
77 GL1000
VT1100 AERO
two CT90
socrace
#159
Post by socrace »
Thanks thunderchild, have always liked your famous Goldwing Cafe!
Latest aspect of this project is getting my handlebar mounted smartphone to monitor and control things, using a $12 bluetooth board from ebay.
Will have some pictures and a write-up, once things warmup a little more here...
#160
I enjoy watching the collaboration. Good job gentlemen.
socrace
#161
Post by socrace »
Well, installed another gadget on the old girl (the bike, that is). This time it's a bluetooth adapter connected to the control cable for microsquirt. So now my Galaxy S5 phone can act as tach, speedo, afr gauge and a few other things, here's a screenshot of the bike idling in the driveway:
The Phone is mounted on a cheap but fairly rugged bicycle handlebar mount, speedometer uses the phones gps and works very well.
Bluetooth adapter is a $7 cheapie from ebay, but took some surgery to work, so would really suggest the $49 one from diyautotue.com for plugandplay.
The software on the phone is ShadowDash and cost was about $10 from Google store.
The Samsung is very bright for a phone, but barely visible in bright sun, so will have to keep looking for something brighter.
AstroWing
#162
Post by AstroWing »
Very cool, I want one.
I have been busy with other projects so I haven't been able to work on my AstroWing much lately. I seem to get all the odd projects. (Just Restored a 1964 International 404 tractor and I'm Building a 1956 Studebaker Golden Hawk custom, also have a 1966 Amphicar waiting) hope to get back on the Wing soon.
Idle seems high for 0% TPS?
#163
Air temp 88 ..... sigh ......
Gord (55 today, I thought that was great) Jones
Toehead
#164
Post by Toehead »
He's probably using a PWM or stepper idle valve instead of a set screw to adjust the idle. That way you can program it to have optimum idle no matter the coolant temperature.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
socrace
#165
Post by socrace »
Yeah, microsquirt wants TPS to be adjusted to show zero at idle.
It was 70 degF today here in Illinois (not too bad!). But sensor is located in manifold where air temp gets higher after idling or heat soak.
