1978 GL 1000 "The Tank" Resoration Project
Re: 1978 GL 1000 "The Tank" Resoration Project
#151
I like!
shieldsm
1978 GL 1000 "The Tank" Resoration Project-Complete
#152
Post by shieldsm »
So my project is complete...Had some performance issues and I finally figured it out last night. It seemed the bike would stutter just off idle and the #1 spark plug was always carbon fouled...so obviously running rich. Turning of the idle adjustment screw did nothing so off with the carbs once more! Adjusted the float once again and noticed the float pin was turned wrong (the spring was facing the wrong way). Not sure if that was the culprit or the float set to high but I immediately noticed a BIG difference. She runs like a dream!!!!!
For those tracking my progress and of course all the help, I can't say how much I appreciate it. I NEVER thought I could and would rebuild a motorcycle from the ground up with absolutely not prior experience. Here is a synopsis of everything that I did.
-New water pump and gaskets/o-rings
-New Barnett Clutch and EBC springs.
-Rebuild Starter (x2). I burned up my first attempt.
-Dyna Coils, Dyna Ignition
-MOFSET Regulator/Rectifier Setup
-New fork seals w/Daystar fork gaiters
-Randaak’s Super Brace
-Randaak’s Front Brake Master Cylinder
-Front and Rear Caliper rebuild
-Complete carb rebuild using Randaak’s Carb kit and DVD (the DVD was worth every penny)!
-Brake Rotors Drilled
-Front SS lines
-New Wheel bearings
-Randaak’s Electronic Fuel Pump
-Upside down Clubman Z-bars
-New metal headlight bucket
-3 yellow wire solder-stator fix
-All new throttle/clutch/choke cables
-Bridgestone Spitfire tires
-Chrome gauge covers
-Modified front and rear fender (a hacksaw job)
-Emgo Shorty mufflers
-Headers wrapped
-International F16 Windshield
-Halgon Rear Shocks
BEFORE:
AFTER:
#153
Wow, what a remarkable transformation. You've done a super job and documented your process very nicely.
Hal
#154
Post by Hal »
You've certainly given it some major character there!
Nice job. action1
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
2002 Caterham SV 220 Evo (4 wheeled motorcycle) :mrgreen:
Hal's Nalbum
#155
Time to ride the pants off her, nice detail on the restoration.
gearhead4207
My Album: http://s1366.photobucket.com/user/gearh ... %20Uploads
#156
Post by gearhead4207 »
nice i like it great job anim-cheers1
83 gl 1100 i stripped gone but not forgotton! :(
82gl1100sold :( black betty
81 gl1100sold :(
78 gl1000 bagger mongrel sold miss you my friend :(
87 aspencade sold :(
84 aspencade f4-b build :mrgreen:back
87aspy stripping for road warrior :mrgreen:
duke182
My Album: http://ngwclub.com/gallery/v/wingmans/duke182/
#157
Post by duke182 »
found your thread today.
read it through and must say, excellent job.
great thread and even better results with the bike.
i hope you get many miles of enjoyment from it.
1984 1200 standard
click pic to see my gallery
vote in my poll
#158
How about a detailed ride report? Seems like you have had her running well for a couple months now.
