Pedro!'s rebuilding projects
- Pedrotq
Set the hub up in the milling machine on the rotary table so i can drill 18 x 8mm holes evenly around her circumference.
Bought some 3mm steel sheeting and roughly cut out two circles with an angle grinder.
Drilled the same 18 x 8mm holes in the steel plate circles.
Bolted them to the hub so i can machine them down to size.
Perth, Western Australia.
- Pedrotq
Now i have two nice concentric flanges.
Using all the measurements i took carefully and evenly TIG weld the flange into the blank rim.
Machine a chamfer on the edge of the hub to accommodate the weld bead on the flange.
- Pedrotq
Bead blast the hub and the rim.
- Pedrotq
Bolt the hub into the rim and paint the left side black along with the rim.
I was too impatient and didn't allow enough time for the first black coat to dry properly so it went all wrinkly with the second application
No worries nobody sees that side anyway
- Pedrotq
Runs central and true
Now the rim is wider i have to fit the final drive to the wheel before i can fit the wheel into the swingarm.
Fitted new tyre and assembled her.
Unfortunately that's where i started missing photos so i will have to take some today and publish them later.
I also fitted new bearings and seals to the hub for a reliable service life.
- Pedrotq
Now all that was the easy stuff, the nightmares are about to start
The rear wheel is now off centre and to the left about an inch or so;
The left shockie will now not fit as it interferes with the wheel.
The stock mudguard will no longer do.
the fuse box / relay box will no longer fit.
the left saddlebag will no longer fit.
I found a thinner shockie with the same travel but a little shorter so i have to move the left shockie mount on the swingarm.
I had to lengthen the shockie/brake support bolt and cut up the existing shockie mount. This is my first attempt, i cut this all off and redid it all (pic to follow later).
I bought a wheel arch from a trailer shop and it will need some fitting to make it work.
- Pedrotq
Now for all those (including myself) who wondered what is under the plates on the swingarm ..... Nothing!
But she rings like a bell without them.
All the relays have to be relocated somewhere else on the bike, i opted for just above the rear wheelarch.
Well that's it for now, i will snap some photos today of the shockie, relays and the work still happening on the saddlebag.
Happy and Safe Riding to Everyone, Peter
Awesome to see you back working again!!!
Wow I have missed your wonderful fabrication and amazing design skills and imagination, great to see you back and hope all goes well with the tests
An ultimate darksider - welcome to the club! BTW, may I suggest a PET scan? Just to be sure. Although, with your brain activity it is liable to not be able to show any metabolic activity that exceeds your normal thought process.
I want to come sit in your garage, drink coffee and watch you design and fabricate.
- Pedrotq
Thanks for the Welcome Guys
I have had CAT, PET and MRI scans, here is one slice of the latest MRI scan, the white streak down the middle is not supposed to be there.
I had to put the left shockie onto the right side, the air shock has been ditched into the scrap bin and another shockie in place on the left, i made a bushing to move the top out about 30mm, the bottom mount is now the right height and out about 0mm too and with a gap under for the brake line.
- Pedrotq
I managed to keep the fuse box where it was, but the relays had to go elsewhere.
I put new relays in that have a mounting tab on them, also they are just a tad smaller and have the same pin configuration as the old ones. which i got from "Eastern Beaver" he is in Japan and has lots of nice electrical goodies for motorcycles.
As you can see the rear wheel is now off to the left, this is of no concern as i am riding a sidecar outfit and will probably enhance the handling anyway?
- Pedrotq
The right saddlebag only needed the mudguard flange cut off to fit into its original position.
The left saddlebag was not so accommodating, i had to cut a big chunk of storage capacity out to clear the tyre and mudguard, then make a blanking plate out of some ABS sheeting which i am gluing in place.
I also have to move the air pump and the only place it will go comfortably is inside the left saddlebag, it is difficult to access the left saddlebag with the sidecar boat in position and i only keep the tool kit, puncture repair kit, towels, first aid kit and toilet rolls in there anyway.
- Pedrotq
It is not necessary but i like to be uniquely different so i have obtained a tail light assembly from a 1999 GL-1500, the one with the clear indicator lenses, they use Amber globes in them.
I only use the right indicator on the bike as the left must be on the sidecar so I will use the left clear lens for a reverse light.
I cut the amber lens off my old tail light assembly and will glue it in place soon.
To get the lens off i soaked the complete tail light assembly in my parts washer which is filled with kerosene for a couple of weeks, the glue/sealant just melted away so the lens popped off easily.
As you can see the work on my Naked 90 has come to a complete stop, i have been collecting components off e-bay for its resurrection which i am looking forward to completing. This will replace my Valkyrie that i lost to my brother Robert who has polished her up magnificently.
That's it for now,
Happy n Safe Ridin to All, Pedro!
That's it for now,
