VAINCRE PROJECT BLOG
Bert
Re: VAINCRE PROJECT BLOG
#196
Post by Bert »
I like the paint color you've chosen.
"Try to be the person your dog THINKS YOU ARE"
'75 Red Wing Now Greene and Tan
'76 Yellow Wing...Sold
'77 Blue Wing
'77 Red/black wing with side car...Sold
'79 Silver/black CBX...Sold
'81 CB1100RB Red and white...Sold
'06 Ducati MTS 1000DS...SOLD
'01 CBR1100XX Redbird
#197
Nothing wrong with that yellow hue, and a lot is perfect.
#198
Very nice color.
I think it'll pop quite a bit better than the original.
bladredhead
#199
Post by bladredhead »
robin1731 wrote: Image
so robin, i see that the exhaust valve is in place but the intake is not. i thought CCing was only really to get the actual chamber volume not the intake runner + chamber?
are my eyes deceiving me?
nevermind, yes my eyes were lying i see it now
#200
Yep, spark plug in there too. Those are not the valves that will be going in when complete though. I don't have those yet. Hopefully tomorrow.
#201
Any idea yet on how much the compression will drop from this tweeking? Seems miniscule, but maybe it takes less than I'm thinking to drop it down a bit.
#202
ericheath wrote:Any idea yet on how much the compression will drop from this tweeking? Seems miniscule, but maybe it takes less than I'm thinking to drop it down a bit.
Can't tell without having pistons and then measuring the head gaskets too. We weren't really looking to drop it so much as helping to prevent some detonation. I could drop it a little more by having the machine shop sink the valves more when he does the valve job. I don't want to try getting too fancy though. This isn't a race bike. It is going to be street ridden. So lowering compression much at all would hurt performance. If it drops more than 1 or 2 points I'd be surprised.
Besides, all that kind of work doesn't come cheap. ;)
#203
Painting is starting to come together. Painting reminds me of an old military adage. "Detail is perfection, and perfection is no detail!"..
So here are the valve cover emblems being redone.
Emblems soaked in paint remover and old paint removed.
Place emblems in styrofoam to level up.
Mix 1:1 thinner and paint in cup
Apply paint with curved nose eye dropper. drip slowly and allow paint to spread.
Apply paint in small spaces using a toothpick or (in Franks honor) the wood end of an incense stick.
Wipe any overruns with the paper end of a match.
Allow to dry.
Oldewing
Secretary
Secretary
#204
Post by Oldewing »
Don't forget the center of the "A"
matalex60
#205
Post by matalex60 »
Awesome! I was wondering how to clean these up. action1 action1
Matalex
Current Bikes:
1975 GL1000 Bobber
1975 GL1000 Candy Blue Green Restoration
1977 GL1000 Black Restoration
1984 GL1200 Interstate all original
#206
I catch that "A" after the rest is dry...
#207
That is gonna look good.
Jeff K
#208
Post by Jeff K »
sunnbobb wrote:I have not decided on the carb yet. It will be a "suck through" system, and I have to add oil cooling and blow off valves. Don't want that plenum to become a bomb!!!
If you stick with the ribbed serpentine belts you don't need the blow off valve. They will slip if the blower attempts to spin backward. If you run cogged belts then you need a safety valve. I have ribbed belts and am running 10PSI boost without a problem. They also track better than the cogged belts, a bit more forgiving on misalignment. The first gen eaton I have is cogged and the belt is always wanting to walk off the pulley one direction of the other.
Also, I can't find any spec on the rotation of the AMR 500. Do they make one that spins the right direction? Or are you going to have to make a bottom drive setup? That is a pain.
Jeff
99 Valkyrie, Super Valk, Supercharged and Fuel Injected
99 Valkyrie Interstate, Stock
92 Vmax Mostly Stock
97 Valkyrie Supercharged and fuel injected.
2004 VTX 1300C
Antique Dynojet Dynamometer
#209
Good points Jeff. I will have to research that question. As I understand it, the blow off valve is needed in case of a back fire up the plenum.
Jeff K
#210
Post by Jeff K »
sunnbobb wrote:Good points Jeff. I will have to research that question. As I understand it, the blow off valve is needed in case of a back fire up the plenum.
Shouldn't need it with the ribbed belts. During the time I was tuning my EFI I had a few episodes of backfire. I heard the pop, and the belt squeal.
If the AMR500 is CW only you'd have to drive it like this... I sent them an email to ask about direction. I'm looking of a supercharger for mine also. It almost looks like you could spin it either way just by turning it over. If it will run that way. Might be a great find.
2004 VTX 1300C
