JENVEY TF 40mm Twin Throttle Bodies "Alberta Super Clipper"
Re: JENVEY TF 40mm Twin Throttle Bodies "Alberta Super Clipp
#211
I am real good friends with my Snap-On guy too. He has my phone number and I have his cell number. :roll:
I will admit I don't have a lot of stuff from his truck though.
Casper
#212
Post by Casper »
I also do not have a whole lot of Snap On tools in my box. Good stuff, as we all know, but dang they are expensive.
Casper
#213
Post by Casper »
To do the high pressure fuel pump install the right way I found out I needed more parts, so more parts are on order :-?
I figured out the final location for the Wideband O2 sensor, pics below. I will send it off to the TIG welder this week to have the steel bung welded inplace. I should be able to install/remove the actual sensor without having to remove, or even move, the muffler. Being the horseshoe it did make the job easy, as there is lots of room to work with. The Wideband system I am using has a dual input option, so if you where running a true dual exhaust it can handle it, in my case I just need to use the one sensor.
I decided to reverse the Jenvey Throttle Bodies, so as to keep the injectors on the inside. I think it provides much more protection for the injectors and the associated wiring, along with all the fuel and MP lines. It will also make for a much cleaner install look on the outside. I'll try and post some pics this week.
Cheers,
irishcarbomb
#214
Post by irishcarbomb »
That's a nice spot for the sensor...what wideband controller are you using?
#215
I am surprised you are using the stock exhaust. Seems you would be adding the blower to make power but then choking it down with the stock muffler. I'm not talking open pipes but a free flowing exhaust would work much better. IMO
Casper
#216
Post by Casper »
icb, I hope the link works. It is an Edelbrock system, very compact low power and water proof.
http://www.edelbrock.com/automotive/mc/ ... ents.shtml
Robin, A very good comment, thanks. The final bike will be a bit eclectic, and that is by plan. A mix of old and new, some modern high performance, and some old school styling. Given the boost levels I am going with and my 'old guy' riding style I think the horseshoe will be fine. None the less all suggestions are welcome.
Cheers,
#217
Casper wrote:icb, I hope the link works. It is an Edelbrock system, very compact low power and water proof.
Cheers,
But remember, you are adding a lot more air into the engine than stock. The stock exhaust may cause a pretty bad restriction. Enough to make it run worse than if it was more open. Even at low boost levels. Just something to think about. ;)
Casper
#218
Post by Casper »
Robin, point very well taken. I do know you have a significant performance motorcycle racing background, and I should indeed listen. How would suggest I you do the exhaust?
#219
Casper and others around him will hear lots of sewing machine sound with the stock exhaust and the added whine of the supercharger. Stealth Super Clipper. It will be easy enough to swap should you choose, however, with all the work likely ahead mapping, it might behoove a change.
socrace
#220
Post by socrace »
You could see if there's a serious restriction by temporarily mounting an exhaust pressure gauge in the O2 sensor location. Most experts say look for no more than 1-2 psi at max power. I'm guessing that adding 20-30hp isn't going to go over that, but the horseshoe is a very quiet muffler so who knows?
#221
Casper wrote:Robin, point very well taken. I do know you have a significant performance motorcycle racing background, and I should indeed listen. How would suggest I you do the exhaust?
I think even the Harley Sportster mufflers would work well. Decent flow and not too loud. You would need to use two O2 sensors but you say the computer is set up for that. If you too open then they get loud. Nobody around us likes loud pipes. I don't when I'm in my cage. I don't when I'm not at the track. ;)
Oldewing
Secretary
Secretary
#222
Post by Oldewing »
It does get loud in your shop from time to time...... :crosso :crosso :crosso
Winston's race bike was a little ..............
Casper
#223
Post by Casper »
Guys,
Some good ideas, thanks.
I have a NOS set of Harley Sportster muffles sitting in a box on the shelf, (got them for free from a buddy) all I need is an other Edelbrock O2 sensor and a two new weld on Bungs. The Edelbrock WideBand unit I have does have a second input, it is set up for a single , or a, true dual Exahust system, so that part is easy. I think I will still go ahead with the Horseshoe, but also put some bungs on the Harley's and bring in another O2 sensor. The swap back and forth would be easy. Once I get the SDS tuning down pat I am pretty sure the change in EFI setting would be also be easy, or I hope so.
Cheers,
gregforesi
#224
Post by gregforesi »
More food for thought...
Millright's 1100 Weber bike has a nice looking exhaust with the baffle stack that can be adjusted. He has installed O2 sensors on both sides and it looks pretty darn good, ain't overly loud, and is tune-able by changing the number of plates in the baffle stack.
You could tune the exhaust for best performance, and then take some baffles out so it was nice and quiet, and have a second map for that exhaust config. It wouldn't take more than 10 minutes or so of wrenching any time you wanted to switch from "quiet" to "performance".
2006 GL1800 (Brutus Maximus)
irishcarbomb
#225
Before configuring for two sensors...
Does the SDS do sequential injection? If so then it may be worth the extra cost. However if it is batch fire (like the microsquirt), each injector bank controls an injector on either side of the engine due to firing order. I originally planned for two, but can only adjust 1&2 together or 3&4. So an O2 on both sides would be purely for monitoring one side, and your tune/ego correction is based off the other.
I have to get back to work, so if that doesn't make sense I'll be back on in a bit to clarify.
