CB750 K0/K1 Hybrid
cfairweather
Re: CB750 K2- I Miss Shaft Drive
What was the tensile strength of the chain when you bought it? If it was one of the low end DID chains, they are only about 6930 pounds. So many chains have broken the cases on CB750s and it is because of poor quality chains. The minimum DID chain for a CB750 would be a NZ model which has a tensile strength of 8600 pounds. This is the one I selected for my last CB750 project and after seeing your post, I am going to order a new chain of better quality to replace it. One that has 9000+ pounds and with a riveted master link. The one I have now has a removable master link. I am also going to get new sprockets for that bike and plan to use 18/45 instead of the 18/48 to lower the highway RPMs a bit. Good luck.
- Lucien Harpress
I'll be 100% honest, I have no idea. Knowing me I googled "CB750 Drive Chain" and bought one in the price range I could afford (which is probably the lower end).
When I do it again, I'm probably going with the riveted master link as well. We'll see.
I ran regular master link chains on the drag bikes for years. I never broke a chain. Quality chain and good maintenance are key. In the pic with a short piece of the chain hanging down you can see it had tight spots. Maybe from too tight. Maybe from lack of lube. I use chain wax, not lube. Less mess.
cfairweather
I have never had a chain break either and I agree the quality of the chain and keeping it lubed are the most important things; however, the clipped master link seems to be involved with a lot of the chain failures. The highest quality chains don't typically offer a clip style master link. Notice that Lucien mentioned that his master link was MIA. When I was young and broke, I used to use chain from a John Deer Dealer to save money. Seemed like the size was a "50" if I recall correctly. These used a clipped master link and the chain size was close enough to work on the 530 sprockets. I used these chains on my 1970 CB750 for many years and never had any issues. I think the bike had about 60,000 miles on it when I got rid of it. I know, it was a bad idea, but I was broke and it saved me a few bucks.
Shadowjack
Once power levels reached over about 50-60 hp, manufacturers started using endless chains. Probably a cause and effect there. I think the early CB750 failures probably resulted from still having master links. Many small bikes still use them.
cfairweather
Since my last post I did some research and decided to buy a DID 530VX3 chain for my current 1971 CB750 project and I ordered a rivet style master link for my other CB750 that uses a DID 530NZ chain. I also ordered the DID KM500R tool to break and rivet the master link. This tool is very expensive (about $120.00), but it has great reviews. Lucien, consider the 530VX3 when you buy a replacement chain as this chain is very strong (9200 pounds) and it won't stretch much. You can save some money with the 530NZ, but I would make it endless. It comes standard with the clip style master link but has an optional rivet link for an extra $10.00.
- Lucien Harpress
I finally wrestled my spare block inside. Not ENTIRELY sure why- it was locked up every since I brought it home, and has been outside, uncovered, in the rain for several years. Still, I don't need it to work- I just need to get it apart.
Pre-chain break I was planning on using the valve cover anyway, to try to stem the massive oil leak from the tach drive. It just looks like I'm going a bit deeper than I was anticipating. I don't plan on getting too crazy with it until later in the year, but I figure it's not to early to get it soaking in some rust penetrant. Still, I'm kind of curious at just how bad the inside of this looks. Guess I'll find out.
- Lucien Harpress
Re: CB750 K2- Oh My
I had a bit of down-time on my Dream project, and seeing as it was a holiday (even though I got to work regardless), I figured I'd start picking at my locked-up engine, start getting that apart. The goal was to at least get the head off, and well- kids, this is why you don't leave an engine outside, uncovered.
(In my defense, this motor has been locked up since the day I brought it home. That said, I'm sure my leaving it out didn't help things. Good news, I don't need any of these parts. Bad news, I'm going to have a TIME separating it from the parts I DO need. Oh well. Problem for FUTURE Mike. Er, me.)
- flyin900
Re: CB750 K2- Oh My
Well at least it is dry in there. Just not sure what all that stuff is with the two different colours of ??? material.
Current Bikes:
DISPLAY MODELS:
RIDERS AND FUN TOYS:
DISPLAY MODELS:
- Lucien Harpress
Re: CB750 K2- Oh My
Three, if you count the dirt and crud in pots 1 and 4...
Shadowjack
Re: CB750 K2- Oh My
You will never get those pistons out without pressing them. Aren't you glad you can pull the bottom case and remove the rod bolts to get the barrels off with pistons inside? Or not...
Re: CB750 K2- Oh My
All I can think is to mark where each piston is (after cleaning what you can from above the cylinders), put the head back on with valves but no cam, and put adapters with grease nipples on the top two, then grease gun and hydraulics. May be a fruitless effort, but might jack the jugs off the case.
- Lucien Harpress
Re: CB750 K2- Oh My
Yeah, I've got a couple months to play with it to see what I can get it to do. Spare motors come up often enough that it's an option I've always got in the back of my mind, so if this becomes more trouble than it's worth I can bail on it. I never figured it'd be easy, but.... eh, we'll see.
- Lucien Harpress
Re: CB750 K2- Oh My
Well, easy part is done.
As you can see, they're not 100% stripped, and the cylinder head studs will be getting replaced as well, but we're farther than I kind of expected to be with this engine. I took vague notes as parts came out (and I still have all/most of them), but as the plan is to re-use all the internals of my current engine, I figured I learn how to do it correctly once THAT one comes apart.
I've never done a bottom end before, and while things don't look impossible, it's going to be an adventure. Mostly making sure all the bearings, o-rings, and clips are where they're supposed to be before closing everything up, and correct order of assembly. I've got a Clymer's manual, but on the other hand... Clymers.
Oh well. One step at a time, once I get there.
cfairweather
Re: CB750 K2- Case Study
Lucien- I have done several of these 750s and am currently rebuilding a 1971 K1 CB750. I just finished putting the last engine cover on it today and will be testing it this week if things go well. If you need help, send me a PM as I might be able to help answer some of your questions.
