GL 1000 cafe fighter
Re: GL 1000 cafe fighter
Exceptional work!!
- EHE
UK_Andy wrote:Love the CBR, is it going to be a solo with leading link?
Thanks for all the compliments.
The cbr is going to get a sidecar in januari, but thats been done by the owner himself.
I just needed to build him a leading link.
Yesterday I spend hours and hours to look and think about the footpegs in relation towards the exhaust. And decided i want to keep the original position after all, but with the zx6r controls. So i need to build two small subframes for that... Which means more work for the overtight schedule...
not more work.......more fun!
- EHE
pictures to show what I meant in my previous post.
the foodpegs make it a big mess of intervering lines and also the exhaust needs to go backwards more then I want.
and last but not least: i expected to make te seat more comfortable by placing the foodpegs a little bit backwards, but on the contrary...
probably also because I don't want to give it extreme clipp ons, but a more active straight up position with wider bars.
okay, this is without the pegs on, but you I'm sure you all just can admit it will bring a much cleaner look.
So indeed Cyborg: it will gain much more fun
talking about Fun: i'm seriously considering to also make the lower triple tree plate in the same way as the upper... (The Fun is never the trouble, but I seem to bring myself into trouble every time again and again by keep changing the plans and getting more and more extreme ....
Plans are meant to be changed.....especially as you go
- bladredhead
The tube top triple is very cool! Do you plan to do any post welding machining to keep everything parallel?
- EHE
i'll try to weld in a smart order... and I will build a welding mould to keep things parallel and then I hope I will be safe as there is no tolerance left for post machining.
its a concern for sure, but we'll see. I might be Lucky
I spend Xmas eve to shape the bars. It took me several hours before i was satisfied...
but now I'm pretty happy with the result.
the seat position will be a little bit bending forward for my back, but for sure not too extreme as I want this bike to make many miles.
probably a low pair of clipons might look cooler, but this will gain more riding fun and it still looks low enough for me.
- duke182
Progress
Merry Christmas
Merry Christmas
1984 1200 standard
click pic to see my gallery
vote in my poll
1984 1200 standard
vote in my poll
- EHE
and welded the triple tree / bars
machined some thread bushings for the clamping ears
and welded them in place
made a slit with a grinder blade on my milling machine. and after that i drilled the thread out of the first part
- EHE
interesting idea. look forward to seeing it on the bike. are you changing the fork angle?
- EHE
I lifted the back of the bike a little bit. But further on no changes on the bikes geometry
Great work as usual.
im liking it. I wish I had access to machining equiptment
My GL1100 Bobber build
http://www.ngwclub.com/forum/viewtopic.php?f=16&t=57946
Cm drop seat bobber build
http://www.ngwclub.com/forum/viewtopic.php?f=13&t=59199
My home built tools and misc projects
http://www.ngwclub.com/forum/viewtopic. ... 58#p637558
