Well there you go..irishcarbomb wrote: The turbo oil seals aren't meant to hold pressure, if it backs up the oil will leak past and it'll smoke like crazy.
Do you regulate (dial down) the incoming pressure at all?
Usually on a ball bearing turbo you use a restrictor in the turbos oil inlet, but this turbo is a journal bearing so full flow should be fine.HOTT wrote:Well there you go..irishcarbomb wrote: The turbo oil seals aren't meant to hold pressure, if it backs up the oil will leak past and it'll smoke like crazy.
I was originally planning on the HKS since it doesn't require springs or adjustment, it works with any amount of boost. But space seemed like a limiting factor.Casper wrote:Great progress icb, what BOV did you go with? The HKS one I have, so far, is proving to be a challenge to mount, yours looks a bit smaller.
