using the centerstand
alegauna
#31
Post by alegauna »
Cookie wrote:Can you imagine the tiny Japanese test rider who first put it up? I bet he was a martial arts expert.
:lol: I think the same!!! each time i try :lol: :lol: :lol:
http://www.youtube.com/watch?v=8hem08a355w
http://www.youtube.com/watch?v=PjQIUEh5zxE
:shock: look this http://www.youtube.com/watch?v=1N2KdXHejMM
GL1000 `78
KZ440 C2 `81
105594
Lead Member
Lead Member
center stand
#32
Post by 105594 »
I took mine off the bike. I kept dragging it in corners and that's a good way to gain gray hair. I know that on a road trip I may have to call AAA, but I won't be calling an ambulance.
Everyone wants to go to heaven, but no one wants to die! '81 CB750 C, '82 GL1100
Re: center stand
#33
105594 wrote:I took mine off the bike. I kept dragging it in corners and that's a good way to gain gray hair. I know that on a road trip I may have to call AAA, but I won't be calling an ambulance.
You need to check your shocks. On a bike with poor or sagging shocks that will happen. On a bike properly set up the foot pegs will hit first on the right hand side and the stand and foot pegs will hit about the same time on the left side.
105594
Lead Member
Lead Member
Center stand
#34
Post by 105594 »
Hey Whiskerfish, I am running shorter shocks. I took a pair of HD sportster 11 inchers and trimmed the lower attach points to fit. I do occassionally scrape the pegs when cranking hard. Andy.
gritter
#35
Post by gritter »
I find the Wing especially easy compared to the BMW R1150 GS Adventure w/Jesse bags... It is ALL IN THE TECHNIQUE.
Once you get it, you'll wonder why you ever struggled!
Stand to the LEFT of the bike, with left hand on left handle bar grip and right hand on the seat rail.
FOCUS on STRAIGHTENING your body. The part from your right arm and your right foot on the centre stand. You DON'T lift. It's more of a LEG PRESS type maneuver. Keep your right arm straight, you don't want to "curl" it or even really use ANY arm muscles. The left hand is for balance on the handlebar.
I always leave the side stand down, just in case I did lose balance, I tend to favor the "left" side.
You do a "LEG PRESS" on the centre stand, and FOCUS on straightening your leg, mostly. Once you get the hang of it, it's so easy! (Hardly any muscles needed!) Great design IMHO.
I find once it's 60% there, putting all my weight on the the foot makes it happen.
Gritter Flash
Neil
#36
Post by Neil »
Good technique. The only difference for me is I also use my hard bag rail and the wing goes right up. One reason I decided to just go topless instead of completely nekkid, the old girl did not want to be embarrased and the hard bags make the job of lifting to the center stand easier. wheelchair
78AZWing
#37
Post by 78AZWing »
Back in the '80's I remember seeing a gizmo that was the cat's meaow!
A kinda self-actuating ratcheting jack center stand, if you will.
You would put the centerstand down and gently rock the bike to the left then right, and it would lift the rear by it'sself.
Any one remember one of those?
For that run-down feeling -
Try Jaywalking!
1978 'Wing with Weber conversion, UnDressed
1976 Junkyard 'Wing with a Dyna ignition. Otherwise undressed.
Proud member of the "NGW CARTEL"
RIP: 1950-2011
#38
Post by Cookie »
the 60s and 70s pretty much made me miss the 80s.
abert51
Re: using the centerstand
#39
Post by abert51 »
the center stand is all about leverage and TIMING. 75% of the effort is ramming the c stand down with all of your weight and the other 20 - 25 % is a guiding, NOT pulling, of the bike up and little back. I am 5'6" 190 lbs. and have little problem on a smooth hard surface. After a couple of successful ally-oops, you will notice that the center stand foot does all the hard work and you will feel the sensation of the stand acting as a crow bar type lever. Really.....
78 Nekid
73 Shovel
73 Tiger
71 Commando
67 305
70 450 Scram
2002 Spirit 750
79 CB 750 Anniversary
mbs.
puffy75
Early 'Wing Guru
Early 'Wing Guru
My Album: http://www.ngwclub.com/gallery3/index.p ... ns/puffy75
#40
Post by puffy75 »
There is an advise tab on my website. Go to Tips and find " Can you stand it?"
May The Fours Be With You.
CB77 1965 First Bike
GL1000 1975 "Puffy" damaged in accident
CB750F2 1978
GL1000 1976 "Puffy Too"
Rexsname
#41
Post by Rexsname »
I never knew it was supposed to be difficult :shock: My first bike didn't have a functional side stand so I had to learn how to get off of it while still balancing it before I could put it up on the centerstand. Stand on the lever and it just comes right up.
REX
1982 GL1100
giant81
#42
Post by giant81 »
I found a video that shows how to do it easily
http://www.youtube.com/watch?v=8hem08a3 ... re=related
what you will notice is as he twists to his left, he is not pulling on the handlebars. He's lifting UP with his RIGHT hand on the rear.
This made all the difference. I'm not a small guy but I always had problems centerstaning a bike until I learned the trick of pulling UP on the rear. Now I can centerstand anything easily.
EDIT: should have read further into the thread before posting, I see someone else already posted that same video.
"The only way to earn bragging rights, is to do shit worth bragging about!!" -- ME
"Make it go before show, you can't drive pretty!" --My brother
"There is no such thing as reality, there is only perception." --unknown
R.I.P. 1981 GL1100 :(
riding in the meantime 2004 zx-10r (friends bike)
hoping to find, anything more comfortable than the rocket.
agreendaya
#43
Post by agreendaya »
How about getting it OFF the center stand? Here's where I run into trouble. Sometimes takes a try or two, but with boots on, and grabbing the frame just aft of the side cover on the left side, I can get 'er on the stand. It's getting the thing back down that's tough. Is there some trick that I'm missing?
'78 'Wing (With '77 motor, and soon to be '77 carbs)
#44
agreendaya wrote:How about getting it OFF the center stand? Here's where I run into trouble. Sometimes takes a try or two, but with boots on, and grabbing the frame just aft of the side cover on the left side, I can get 'er on the stand. It's getting the thing back down that's tough. Is there some trick that I'm missing?
Often that is a result of the center stand support being slightly twisted forward. That can be a indication of frame rot discussed here http://www.ngwclub.com/forum/viewtopic.php?f=8&t=11785
scooterboi
#45
Post by scooterboi »
I stand on the handle that sticks out and lift on the front part of the luggage rack. Both feet off the ground. I am, for a moment, a jack. I am 6 ft tall and weigh 165 lb. It is not all that hard for me but I do appreciate the side stand, and use it most of the time. The PO never used the sidestand and would risk life and limb checking the oil level. He is several inches shorter than me but much heavier and stronger. Hockey player! I was a XC runner.
"Deep in the heart of every human being...the drive to demonstrate competence." R. Buckminster Fuller
1965 Heinkel Tourist 103A2
1960 Heinkel tourist 103A2
