viewtopic.php?t=79155#p830592
Engine removal
agreendaya
Re: Engine removal
#31
Post by agreendaya »
OK, so perhaps a silly question, but it doesn't look to me like it's quite necessary to take off the belt covers and oil filter in the front, looks like there oughta be enough room. Am I totally off-base?
'78 'Wing (With '77 motor, and soon to be '77 carbs)
Re: Engine removal
#32
drop it down a little and it should come out with them on
wingman76
Re: Engine removal
#33
Post by wingman76 »
sorry...had a snap ring ?...but I got it out
80 GL1100I Naked
76 CB750K
76 GL1000 sitting..trying to decide what to do with
72 CB750K2... ugly, sitting for 20 years in a real barn
08 KTM 450 EXC-R
numerous dirt bikes
Life AMA
dl1000
Re: Engine removal
#34
Post by dl1000 »
To get my starter wire off i had to grind a 10 mil. open end wrench so it was thinner, then it fit on the inner nut and i could remove the outer nut and wire without damage to the starter. Hope that helps.
1978 GL1000.....KATE Daily ride
a very wise man once said nothing
Hal
Re: Engine removal
#35
Post by Hal »
dl1000 wrote:To get my starter wire off i had to grind a 10 mil. open end wrench so it was thinner, then it fit on the inner nut and i could remove the outer nut and wire without damage to the starter. Hope that helps.
I just did the same thing. It's now a 'special tool'.I wonder if there's a bicycle type 10mm in the OE toolkit?
It's also hard to find a plug spanner that fits...the OE one is the only tool I have that can be used!
I had a struggle to get the engine to move down and forward on the rig, but after a while with two of us cursing at it, I realised the front crossbolt was still in on the right side. This is what comes of working with someone else who doesn't know the bike. He had taken off the removable left rail, but hadn't mentioned the crossbolt, and I hadn't seen it as on the right side it is hidden by a big mounting plate for the rig!
All most amusing..... :roll:
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
2002 Caterham SV 220 Evo (4 wheeled motorcycle) :mrgreen:
Hal's Nalbum
Oldewing
Secretary
Secretary
Re: Engine removal
#36
Post by Oldewing »
Don't know about your side of the Pond, but a 18mm deep socket works on my plugs over here..
SlyDogJeff77
Re: Engine removal
#37
Post by SlyDogJeff77 »
many of the images are no longer showing up?
Life is short! Live it now because today will NEVER happen again!
My 1983 GL1100 restoration Project (In Progress) 3rd times the charm!
https://www.ngwclub.com/forum/viewtopic ... 30&t=72987
My 1980 GL1100 restoration project (DEAD) and sad...
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=52276
My 1982 GL1100 restoration project (DEAD) and sad...
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=34697
Re: Engine removal
#38
Bicycle wrenches are sized for cone nuts so they are very thin. Very handy at times.
Re: Engine removal
#39
SlyDogJeff77 wrote:many of the images are no longer showing up?
Should be fixed now. Part of the Gallery upgrade issues.
Hukmut
Re: Engine removal
#40
Post by Hukmut »
Thanks for the tutorial. Timely! As I am about to remove the engine from my '81 1100i. Going to do a "clean-up" while waiting for parts. I will also be doing a thorough "study" of the electrics while I am there. :orange After looking it over, trying to decide on the removal, I noticed that the engine was never fully installed with all the bolts in place! :shock:Betcha when it goes back in there will be bolts where they are supposed to be bolts! :orange
And then there is the matter of the carburetor... Another day. One thing at a time, please! ;)
Experience is what you get when you didn't get what you wanted.
Do your work with your whole heart and you will succeed! There is so little competition.
Come to kindly terms with your ass, for IT bears YOU!
1999 Valkyrie built from parts. One owner. :crosso
1981 gl1100 naked, Cosicud. :orange Sold!
1981 gl1100 naked. New project. :-D
Re: Engine removal
#41
If the engine was out sometime in the past then it is possible some of the threads are boogered up. Might want to check them out while you have the engine on the deck. Also on the re install make sure to leave everything loose until all the mounts are started. Sometimes she needs a nudge this way or that.
Hukmut
Re: Engine removal
#42
Post by Hukmut »
Thanks for the sage advice! My next trip to HF will be to purchase a metric tap & die set. And I THOUGHT that I had all the tools known to man! Oh, wait, I DID have a set, once upon a time. :orange
Re: Engine removal
#43
Not sure HF would be my first choice for a die and tap set. Their hammers are probably O.K. :lol: :lol:
DocRoot
Re: Engine removal
#44
Post by DocRoot »
+1
I use their TN drillbits, jacks, and hoses, and yes I do like their 8oz stubby hammers, but I no longer buy anything that has to be precise, high strength, or anything with a motor in it, having learned the hard way.
Appreciate good people: they are hard to come by.
Hukmut
Re: Engine removal
#45
Post by Hukmut »
Yes, I agree, but just to chase threads, they (hopefully) should be up to the task. Besides, this is a "crunch budget" project. Between working for the landlord, eating/sleeping & teaching ( I am a pottery instructor), there is *almost* time & money to work on the bike. :orange
Oh, I almost forgot, doing my "research" on this forum as well as ebay, is somewhat time consuming as well.
It is ALL a labor of love. :-D
