Ric's Retro Resto: BOTM June 2010
Pony Ruiz
when you do the powder coating. what happens where there are machine threads for bolts/screws and the like?
do you put a place holder in there i.e. a screw or bolt so no powder gets on the threads or........?
Thanks.
I want to do a similar scheme. I love the old classic paint jobs myself.
bob
Thanks.
bob
It is what it is.
- Sagebrush
The outfit that powder coated my frame was experienced in bike frames. They capped all threaded holes and everything else that looked like it accepted a machined part. They did an excellent job and I had no issues with powder coating contaminating any orifice during reassembly. They also included sand blasting in the price of the powder coat job.
- HOTT
Thanks tigre & Pony; my Ego can never get enough. lol. Threads and surfaces like brake pivot & race inserts can handle media blasting. Don't get me wrong, a heavy handed oil field sand BLASTER could make your swing arm look like a jelly bean. I use glass bead in my two cabinets. As far as the powder coat... it's masked pretty much like paint, keeping in mind it will migrate or attach itself deep inside places paint can't get to like inside swing arm. I kinda like that.'76 frame frt tan Once it's dusted the tape is removed before going in the oven. Your local powder coat guy most likely has experience with frames. Things on a GL I would tell you to do is pop off the vin plate and make sure stamped serial #, rear brake pivot, and rear caliper anchor bolt hole get masked. Every thing else is pretty obvious. You will loose the vinyl coating on your cable retainers but easy fix with heat shrink. Ric
- HOTT
I swear I'm gonna steal this thread and put it in the underground customizing forum... that is some real nice work.
- HOTT
The weather is crazy here in Houston area. Shivering to much to pinstripe today. I know I'm a sissy to you guys in Seattle lol. So here is a look at my rear turn signal install; I wanted to minimize and clean up rear siggs. I drilled an ample size hole above the shock mount and used bicycle cable to pull wires though.
the fixtures I'm using are after market jobbies from Parts Unlimited that come in a variety of styles. They all seem to have the same threaded mounts. Carefully thread into frame using clamp bolt backwards as a lockdown.
Add a little bit of vinyl tube to prevent chafing (I think we all hate chafing).
Ta Da !! So the question remains how do I mount my seat ? Pretty EZ fix but stay tuned and I'll post it soon.
- Ruffrider
- My Album: http://www.ngwclub.com/gallery/v/wingmans/Ruffrider
that's gonna be one sweet ride.....nice work.
Current Bikes I own:
1975 GL1000 Naked Wing, Old Faithful (alias the Ditch Dog)
(88,000 miles and broke down now)
1975 GL1000 Dresser ( project bike, still waiting for me to finish) 20,727k on speedo.
1979 XS1100sf (18,600 miles)
1984 CT110 2300 miles
1978 CT (Trail) 90 1,650 miles on speedo
Past Bikes:
1979 750 Kawasaki LTD
1976 Honda CB360
1975 Honda 400 four
1966 Honda 160 Dream (should've keep 'em all )
My album
Past Bikes:
1976 Honda CB360
1975 Honda 400 four
My album
- HOTT
Well it's been a couple of weeks, between the weather and my indecision the panel painting has taken longer than I thought. I've had no less than FIVE different colors and pattern combos. And I liked them all ! I chose this scheme cuz to me it looks fast and large with just the right amount of 'tude. I still have a lot to do. We had a little sunshine today so I rolled her out for some pix.
Pony Ruiz
That really takes some pounds off it the wing's look. ala BSA
- Sagebrush
Just one word: AWSOME!
