Unless you plan on doing a frame-up EVERY winter, this will be more difficult once you get it back together.Kasl wrote:Ok. It's been a while. I wasn't going to do it but I decided to strip down the whole thing. Yes, it's hanging from the ceiling.....I need to make room for the wifes car in the winter : )
Nova Scotia '76 GL1000 do-over
- roncar
Re: Nova Scotia '76 GL1000 do-over
To clean up the covers, soak them in paint remover. Sand with 400 wet paper. Buff like heck. Polish with metal polish..
- Kasl
- Zinc Member
Ok Sunnbobb, covers soaked, sanded, buffed (poorly) and polished. This is what I got! It's not perfect but that's not what I'm after. I'll settle for reaspectable : )
1976 GL1000
- Hoosier Daddy
Now apply a car wax to help keep them that way.
I pulled the cover off my GL yesterday to find tiny specs of white corrosion already setting in on my polished bits in a matter of months of setting idle, covered!!
Yep, thats why there is a fan running as we speak in the trailer housing my race bikes and the Wing. That helps a little too. Especially in the spring when it gets below freezing at night and then up to 50 or so during the day.Hoosier Daddy wrote:Now apply a car wax to help keep them that way.
- Kasl
- Zinc Member
Some progress today. The engine is in the painted frame and the triple tree is on. Anyone notice that Honda changed from roller bearings in the '75 steering head to needle bearings in the '76 frame......When you're using 2 bikes to make one these things tend to make themselves known : )
1976 GL1000
yes... the 75 certainly had balls
Bert
Going to be a very nice looking clean bike when the build is done.
"Try to be the person your dog THINKS YOU ARE"
'75 Red Wing Now Greene and Tan
'76 Yellow Wing...Sold
'77 Blue Wing
'77 Red/black wing with side car...Sold
'79 Silver/black CBX...Sold
'81 CB1100RB Red and white...Sold
'06 Ducati MTS 1000DS...SOLD
'01 CBR1100XX Redbird
'77 Blue Wing
- Kasl
- Zinc Member
Finally 17" rear rim is spoked to front hub. Had to shorten original spokes approx 1". Got the new thread rolled properly at Buchannan's Spoke & Rim (thanks Angel. Great job and good price too) Opened up diameter of spoke holes in rim a few drill sizes to adjust for new spoke angle and made custom cup washers between spoke nipples and rim to make up the difference and distribute load to edges of rim spoke indent and away from the hole itself. It wasn't too bad relacing the hub onto the rim as long as you follow the procedure and take your time. I have a Dunlop D404 120 90 -17 front tire on order to slap onto this.....only front tire I could find that comes close to OD of original front tire and fits on the rear rim. Once the bike is done I'll run her gentle for a while and keep a VERY close eye on the spoke tension. Also have new seals, guides and oil in front forks. Old rotors are true within 0.002".....lucky.
1976 GL1000
- moonshiner
Wow, any thoughts on a front fender yet. Gonna look great with that 17 inch front wheel.
Very interesting
- OhioBill
- My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
Love the 17" front wheel. I want to do the same with mine. Great build!
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
- Kasl
- Zinc Member
Hi Ohiobill,
I'm hopeful this works out. I'll have a tire on it next week but it'll be a few another few months before it's on the road. I'll certainly be checking spoke tension regularly once I start riding it. I want to be sure that oversizing the spoke holes in the rim doesn't cause issues. I had to do that to get the spokes pointing the right way because of the much smaller diameter of the front hub vs the back hub. That's why I made large cup style washers directly underneath the spoke nipples...to distribute the load around the edges of the rim spoke indent and away from the edges of the hole itself. In any case, my point is modifying the rim is usually frowned upon so be very careful that everything is sound and secure and check spoke tension and rim condition regularly when you start riding on this mod : )
1976 GL1000
- Boufie
- My Album: http://tinyurl.com/2dma28f
I love to see these frame-off builds...it looks like you are doing a great job. I always liked the big front tire / rim on Octane's Bulldog, cant wait to see your pics of that. Nice exhaust too! Happy wrenching and good luck...
John B.
1978 GL1000
1978 GL1000
