76 GLCR - Goldwing Cafe Racer
SlyDogJeff77
Re: 76 GLCR - Goldwing Cafe Racer
#31
Post by SlyDogJeff77 »
How much did they charge to cover the seat?
Life is short! Live it now because today will NEVER happen again!
My 1983 GL1100 restoration Project (In Progress) 3rd times the charm!
https://www.ngwclub.com/forum/viewtopic ... 30&t=72987
My 1980 GL1100 restoration project (DEAD) and sad...
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=52276
My 1982 GL1100 restoration project (DEAD) and sad...
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=34697
Jimbo1
#32
Post by Jimbo1 »
evl_twn:
Did you need to get customized throttle cables for you cafe since you're using shorter bars? I am having issues with the throttle not being able to snap back like it should as well as the throttle staying open after releasing it. I appreciate your feedback and any tips you may have.
Thanks.
gregforesi
#33
Post by gregforesi »
Oh...another little cafe effort rears it's quick little head.
When the bars get a little shorter the cables can often be rerouted. When the bars get a lot shorter you need to shorten the cables. The clutch cable is a pain because of the force it sees and there is no way to reroute it without a kink someplace. The dimension is critical.
The throttle cables are easier to shorten yourself or you can pick up new ones that fit.
For cables I usually take a piece of 1/8" solder and route it through the bike. When you like the way it looks - cut it to length, pull it out, and measure it. There is your cable housing length. Then you need to determine the "stick-out" of the inner cable. Custom cable manufacturers usually know what ends to put on and how much longer the inner cable needs to be.
My clutch cable is a -6. I didn't have to shorten the throttle cable because the Webers required serious re-routing anyway and the push cable isn't used. The -6 clutch cable worked with the dragbars and with the clubman bars.
Ya know boys - Goldwings are huge touring bikes. What are you guys trying to do here anyway?
2006 GL1800 (Brutus Maximus)
Jimbo1
#34
Post by Jimbo1 »
I appreciate the tips on the cables. I'll try the re-routing method first and go from there. The clutch really isn't a problem, shifting seems a-ok.
Why would we want to do that to a Goldwing? Because we can?
#35
Greg, appreciate the details as I am putting on Flanders style Superbike bars, actually the Bikemaster European bar as it was inexpensive in comparison and very similar in width, rise and center spacing. I plan on shortening (cutting back) all the cables and replacing the brake hoses.
