Blew the LH head gasket after exhaust valve adjustment
Re: Blew the LH head gasket after exhaust valve adjustment
North Carolina, Gord?
- alwing17
- Exceptional Member
Honda manual states to coat the threads and both sides of the washer w/Moly90 before torquing to 42-45 ft/lbs in sequence. WF beat me to the post..was in a rush to go to work and now just got homeWhiskerfish wrote:Earl43P wrote:
I installed them clean and dry, nothing except a washer under the bolt heads either (despite the great grease debate).
Sorry but it is not a debate. http://www.ngwclub.com/forum/viewtopic.php?f=8&t=7801 Failure to lube the bolts properly result in a head gasket with insufficient clamping pressure that will fail before it should.
There was an episode of Horsepower TV on Spike channel a while ago that showed the merits and consequences of ARP fasteners and the lube they sell compared to motor oil,grease,and other lubes to lubricate the threads...I think you could find the episode on line...Very interesting!
1975 GL 1000 "Street Fighter"
1976 GL 1000 "Screaming Yellow Zonker"
1976 GL 1000 Sulfur Yellow x2
1981 GL 1100 "Crown Royal"
1997 GL 1500 Pearl Sapphire Black
1977 GL1000 Cirrius Blue
1977 GL 1000 Skidmark build
1976 GL 1000 Limited
2003 ST 1300 Silver Streak
(And those are just the Gold Wings! With an exception..)
Team 898...25%er...*Beverages Consumed
Team LTD...1/6th'er...* Even more beverages consumed
- Earl43P
Ordered a new head gasket.
I have the spline grease.
I don't mind the re-do/$40.
The Clymer manual leaves a lot to be desired, detail-wise.
Thanks for the feedback, all y'all!
2008 GL1800 "yawn"
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
