77 GL Project - Maintenence & Clean Up
Re: 77 GL Project - Maintenence & Clean Up
Bad Sabre Cycle. It would be very bad if you validate for them, but I too have no idea what prior validation was done.
Good job on the breather.
- luludog
Thanks Steve & Fred. You got me thinking I should switch over to Honda belts.
-Ray
1977 GL1000 - http://www.ngwclub.com/forum/viewtopic.php?f=30&t=40398
1975 CB750K5 - stock restoration http://www.ngwclub.com/forum/viewtopic.php?f=13&t=40426
1971 CB175K5 - stock restoration http://www.ngwclub.com/forum/viewtopic. ... 95&start=0
1972 CB350 - resto-mod cafe project http://www.ngwclub.com/forum/viewtopic.php?f=30&t=47429
"Remembering the Past... Liv'n the Dream"
luludog wrote:Thanks Steve & Fred. You got me thinking I should switch over to Honda belts.
Gates belts are what most of us have used. You can get them from any auto parts store. Usually the same or cheaper for both belts as one from Honda. You could also get them from Cascade Cycle. A sponsor of this board. You can check out crossover parts section for part numbers.
- luludog
Got the new belts coming.
Here's the valve covers and belt covers cleaned up.
That's me wearing down the wheels & rouge polishing the covers
After a couple of hours...
-Ray
- matalex60
Great work! I will keep my eye on this one!
Matalex
Current Bikes:
1975 GL1000 Bobber
1975 GL1000 Candy Blue Green Restoration
1977 GL1000 Black Restoration
1984 GL1200 Interstate all original
Current Bikes:
1975 GL1000 Bobber
Looking very sweet, keep up the excellent work.
- luludog
Thanks guys
After I bled the front brakes they still felt a little spongy. I went ahead and held the brake lever in with a bungie cord overnight so any air would rise and come through the compensating port in the master cylinder. I also turn the handlebars to the left (positions it better). Worked great, now the brakes are solid.
-Ray
Not for everyone, but if you bypass the splitter with two lines at the master (double banjo bolt), then they self bleed pretty much. Not sure how you can catch an air bubble once you get the splitter out.
- HandsomeSteve
Great work on the covers! Looking good
Current: 1977 Goldwing, 1982 CB450, 1964 Yamaha YJ1
Retired: 1971 Triumph Blazer, 1970 Triumph Trophy, 1969 Triumph Trophy
1981 Suzuki GS650, 1970 CB100
Very nice polishing job. Where's the after picture of the man who did 'em?
but not the ones from i the showerRoady wrote:Very nice polishing job. Where's the after picture of the man who did 'em?
- luludog
Wife took the pictures and yesssss.... my face looked like I was going trick or treating. Not the first; wouldn't be the last. Its almost a right of passage for polishing.
-Ray
- Pokegama
Nice shine on those covers, great work.
August 2013 BOTM!
August 2013 BOTM!
- luludog
Thanks. Its the "10' shine job". Looks better than they really are.
Anyone know what kind of ignition I have? Its an odd arrangement with what appears to be only one adjustment for timing? It works, but I'd like to know how to adjust it.
-Ray
- luludog
Thought I'd go to the salvage yard this morning. Hit the jackpot with some of the stuff. Found some coolant end caps & tubes in good condition. I'll cut off the float and use the gauge top to seal the tank while its being coated. Not sure about the condition of the diodes or the resistor block. Fuel taps are the rebuildable type (current one isn't)
$2.00
$2.00
-Ray
