78 Scrambler
OhioBill
My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
Re: Tracker style
#31
Post by OhioBill »
As for the carb problem, I'd pursue Old Fogey's suggestion. Remove the floats and fuel valves and plug them as well as the fuel inlet and draw a vacuum and see if the gasket that seals the two halfs of the plenum together is leaking. If so, I'd do a complete overhaul on the carbs.
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
ronajon
Re: Tracker style
#32
Post by ronajon »
First I need to fix the scavenger pump issues. Are there any tutorials on how to do it?
Rdltmc3
Re: Tracker style
#33
Post by Rdltmc3 »
ronajon wrote:
That's a cool seat
1978 gl1000 for sale to fund new project
ronajon
Re: Tracker style
#34
Post by ronajon »
i tried to loosen the bottom bolt by applying heat, unfortunately without result. i think i'll just leave the bolt as is, perhaps shorten in to just fit in the frame and apply a nut to it.
i think i found the solution to the clutch issues also, i opened the scavenger pump today, and the rotor in there is broken in many pieces.
should i check the front pump to be sure?
Re: Tracker style
#35
Hey, that can be repaired with a bit of JBWeld lol. Good thing you found that, must have been something metal got loose to cause that damage.
ronajon
Re: Tracker style
#36
Post by ronajon »
it seems the outer rotor is broken also.
this weekend i'm going to pull the scavenger pump of my other spare engine
hacksaw1945
Re: Tracker style
#37
Post by hacksaw1945 »
Is the engine casting not damaged?
1977 Honda GL 1000, 1982 Honda GL 1100I went naked, 1976 Honda LTD rough long range project, 1945 Indian Chief, 1947 Indian Chief, 1948 Indian Chief, 1958 Cushman Highlander, 1959 Cushman 3 wheel Mailister, 1966 Triumph TR6,
ronajon
Re: Tracker style
#38
Post by ronajon »
hacksaw1945 wrote:Is the engine casting not damaged?
From what, the rotor parts.?
They are very smal, no damage to the engine
Re: Tracker style
#39
Probably want to flush the inside of that case with diesel, there are likely small metal shavings all over.
ronajon
Re: Tracker style
#40
Post by ronajon »
sunnbobb wrote:Probably want to flush the inside of that case with diesel, there are likely small metal shavings all over.
i agree with that.
what is the best procedure to flush? the engine is out of the frame, so cannot run
ronajon
carb issues
#41
Post by ronajon »
last weekend i finally had some time (and good weather) to make progress with the bike.
replaced the broken rotor, replaced the damper plate with 2 friction plates, got the engine back in the frame, reconnected all wiring and got some GL1100 carbs on her. (plugged the vacuum advance)
checked points gap and timing, and synced carbs
now with the gl1100 carbs in place the bike runs nice. but not great :cry:
when running the bike above 3000 rpm, on closing the throttle she does not deaccelerate direct, but keeps on 3000 rpm and then slowly starts lowering in rpm
also throttle response is not great, from idle to accelerate, it takes a fraction of time before she will take off
i read about air cutoff valve which can be faulty, so i'm going to check those.
any more suggestions which need to be checked?
Re: Tracker style
#42
Sounds more like a carb sync is in order. Bad air cut off valves will usually cause backfiring on decel. Not a hanging idle.
ronajon
Re: Tracker style
#43
Post by ronajon »
robin1731 wrote:Sounds more like a carb sync is in order. Bad air cut off valves will usually cause backfiring on decel. Not a hanging idle.
i just did the carb sync.
if it's not air cutoff valve, can it be there is an air leak?
evilratwing
My Album: http://www.photobucket.com/evil03ratwing
Re: Tracker style
#44
Post by evilratwing »
I'd be thinking air leak.
The bike is essentially just another bike... The pilot is CRAZY.
Whargoul - Murdered out 1978 GL1000 - Engine KaBOOM.
Cherry Cough Syrup - 2009 Suzuki M90 - 3,300 miles.
waterboybueche
Zinc Member
Zinc Member
Re: Tracker style
#45
Post by waterboybueche »
Ronajon, Love the tracker style... I am kinda doing the same!
I have learned a couple things from this forum...
1. These old Goldwings sure will make a mechanic out of us!!!
2. You guys know ALOT more about how these things work than I do!!!
1978 GL1000 Purchased April 10th, 2013
Removed fairing, added new tubes and tires, Dirt bike handlebars, new grips, cut down stock seat, trimmed stock fender, new fuel lines, fuel filter, oil and filter change, valve adjust, new fork oil, final gear drive flushed and did Lazy Mans carb clean...
