My Preservation restoration
davhj
Re: My Preservation restoration
#31
Post by davhj »
I'm going to finish the story on my "Preservation Restoration" up to the point where I got it finished, running, off the lift and on the ground then I'll go into what I found that still needed to be fixed and all the fine tuning to get it to the point that I'm confident I can take it for more than a few miles at a time.
Al though I've owned this bike for ten years I never got it running properly and never rode it before I started the project.
Stay tuned.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
1990 Sea Ray 350 Express Cruiser
2000 Harley Davidson Electra Glide Classic
http://www.ngwclub.com/forum/viewtopic.php?f=30&t=46946 (My Preservation Restoration)
davhj
#32
Post by davhj »
All that is left is the carbs. I met a member of this board "SnoBrdr" and I traided a set of Harley mufflers for the Randakk carb Video,
Thanks SnoBrdr. I bought the Carb rebuild kit, reuseable fuel filter and a few other things from Randakk and new needle and seats for the floats from Honda. I watched the video a few times and dove in. Taking the tops apart was pretty much straight forward. one thing that Randakk mentioned that getting the air mixture scerew out on one carb was a bit awkward I found that if you take the plastic thing out that holde the plug wires and put the screw driver through the hole you have a better angle to get it out.
Then when I fliped the carb rack over to remove the float bowls I had quite a suprise. the PO decided to use silicone to seal one of the bowls and it not only seales the bowl but blocked up everything underneith and frose the float.
I striped the rest down and started the cleaning as per Randakk's instructions.
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
davhj
#33
Post by davhj »
Carbs, Part Two. That one carb with the silicone was a disaster, I'll bet I worked on that one carb for two hours removing every bit of silicone.
The other three were just gummed up from old gas not bad.
On to the rebuild, I pretty much followed Randakk's video did the vacuum check on the plenum and fuel side I took great care on adjusting the floats with the new needle and seats installed, made sure every jet was clean, pollished the slides and all that good stuff. I replaced every philip screw on the carbs the others were so buggered up.
Here they are ready to install
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
Lefty
#34
Post by Lefty »
Giant step forward. Carry on the good work.
Been riding Hondas since 1964.
Current bikes:
1985 GL1200i work in progress.
2002 CB750 Nighthawk
#35
The Carbs look great. Bench test the fuel flow and flush out the rest of the system and it's a GO!
davhj
#36
Post by davhj »
It's Easter weekend, I had Good Friday off as a holiday and took Monday April 1'st on vacation I worked on the bike all weekend.
Got it all back together, installed the carbs, new fuel pump, Big crank battery, adjusted all the cables, set the points, static timed it and turned the key on and had everything working except no tail light and no runnung lights. I stole the reserve lighting parts off the 77 and good to go.
Put gas in the tank, the 7 volt reg is working but no fuel gauge reading I'll deal with that later, primed the fuel pump, filled the bowls as per Randakk's video and connected the gas lines.
It's ready to start, pulled the choke, pushed the starter button and fired right up I couldn't beleive it. It stumbled for a while but as it warmed up it started to settle down then discovered the tep gauge is not working and the fan never came on and it started to get hot so I shut it dow.
After it cooled down I started it back up and took it for a one mile ride it ran OK but not perfect and still no fan, fuel or temp. but it is done for the most part. Now I'll tell what I found to fix and complete the story in more posts.
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
Lefty
#37
Post by Lefty »
Darn good looking bike. A good carb synch might be all you need for a smoothly running engine.
Current bikes:
davhj
#38
Post by davhj »
OK, if you'll bear with me for a minute and read posts: 9,11,18,22,26. we'll be up to speed because that's where I am now.
I decided on getting the original ball bearing setup for the steering stem, I got everything in the mail from Western Honda the other day.
The bike will probably be on the back burner for a few weeks till I get my boat in the water, got to keep the wife happy she is a boater and not much of a biker, then back on the bike.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
BigDub
#39
Post by BigDub »
Good thread and thanks for posting your build. i need to try to get my wiring all back together, and try a test crank.
1984 VF1100 Flat Black Saber
1981 GL1100 Flat Black Bagged aka my pickup
1976 MR175 farm/trail bike
1975 GL1000 Antares Red
davhj
#40
Post by davhj »
Well it's been more than a few weeks since I worked on the 75 Wing but last Monday i got the front end off to replace the neck bearings.
I got the new races and ball's in, much better now. I got side tracked again, I hapen to find a deal on a 1981 Interstate for $200.00 I couldn't pass it up. It is a little rough cosmetically but it is workable. someware along the line someone put front calipers from an 82. It will be on the back burner for a while till I finish the 75.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
Griffen
#41
Post by Griffen »
Early onset MBS. Sorry there is no cure lolol
Present Projects
1983 GL1100a
1976 GL1000
Past Rides
1975 Honda 500t
1976 Sportster
1981 Honda cb750
1999 Honda VT1100t
1999 K1100ltc
#42
Post by HOTT »
Really, Really Nice! tumb2 tumb2
($200.00! head in hands)
davhj
#43
Post by davhj »
Not sure if this MBS syndrome is a good thing or not, I paid $200.00 for the 75 and $3,500.00 later, well I know the 75 is a nice bike now.
HOTT don't let the picture fool you the 81 is not that nice, the bags and faring have cracks all over and the paint job is by spray cans. I'm not sure what to do with it yet.
I worked on the 75 today, got most of the front end back on then it got too hot in the garage and I forgot to take some pictures. I'll take a few before I start to work on it again. Hopefully I'll have it back together b the end of the week.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
davhj
#44
Post by davhj »
Got a little more done last night, I'll finish it tonight. I still have an issue with the back brakes to deal with (low Peddle) I've blead all the air out but it is still low. I still have no reading on the gas gauge and water temp gauge, the 7V reg is working so I have to sort that out too.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
davhj
#45
Post by davhj »
The front end is all back together, no more front brake issues. Even though the 7 volt regulator was working I desided to buy the new improved one from Gavscott/Hollsco, I installed it like another member did and I added schrink tubing to the spade connectors. I was reading on Randakk's tech tips on how to jump the leads for the fuel sending unit and the gas gauge came up slowley so I tried the one from the 77 and it responded better so I installed that one. I pluged the wires back to the sending unit and now i have a gas gauge that works. Still no water temp that is next.
I got the bike insured through AARP/Formost got a good deal on both the Harley and Wing, registered, and inspected.
I filled the tank and the gas gauge went to full. the rear brakes seem better not sure why maybe some traped air worked its way out.
I think I might have to balance the front wheel I have to take it up to speed to know for sure.
Time to start riding it more than just in the city a few miles at a time.
Dave
Dave,
1974 Honda CB750
1975 Honda GL1000
1977 Honda GL1000
