Gettin' Naked
Scratcher09
Re: Gettin' Naked
#31
Post by Scratcher09 »
I got a dual head light I am going to install. I know it is a bit different for these bikes, but I like the look. I'll post pics after I install it.
'82 GL1100
Easter
Re: Gettin' Naked
#32
Post by Easter »
The new Sheriffs patrol Goldwings have the dual headlights so you will be in good company.
83 GL in process :IDTS:
Scratcher09
Re: Gettin' Naked
#33
Now that the rear shocks have lowered it about 1 1/4 inch I am finding that putting it on the center stand is DIFFICULT. So I'm thinking I need to shorten the center stand a bit. I use to have a Virago I had lowered and I had to shorten the side stand after lowering. Is there any reason I should not do this to the GW center stand?
'82 GL1100
Easter
Re: Gettin' Naked
#34
Post by Easter »
Dragon Wing is so difficult to get on the center stand even at or near original height that I just eliminated the stand all together on the Just Trash project.
Scratcher09
Re: Gettin' Naked
#35
I wanted to change the handle bars for a different look. I like the look of clip ons but I am 40 and I like long rides so I need to do something that my back can live with. I had an extra set of drag bars (shouldn't it be "a drag bar--singular?). So i put that on and the controls did not have enough room. So i looked online and debated buying some bars in the $50-$70 range. Then I decided to try and hack my stock bars to look like the ones i was looking at online. So here are some pics of what I did.
'82 GL1100
Scratcher09
Re: Gettin' Naked
#36
First pic is what I started with. Then I took a grinding wheel to it.
'82 GL1100
Scratcher09
Re: Gettin' Naked
#37
I used the section I cut out to measure the other side so they would be even. Then I welded the pieces on one side.
'82 GL1100
Scratcher09
Re: Gettin' Naked
#38
After cutting and welding the other side, I felt the bars were too wide overall so I then cut about an inch and a half off each end. I first was going to cut a three inch section out the middle but realized that I could not cut more than one inch out the middle because any more than that would put the bends at odds with the bar clamps. The ends are solid so it was a bit of a job to cut them. I think the inserts are to reduce vibration. I've also heard of people using cement inside bars to reduce vibration. I am happy with the results. I know a more radical design would have looked better to me but I wanted to keep the strain on my back to a minimum.
'82 GL1100
Scratcher09
Re: Gettin' Naked
#39
Here are the bars installed.
'82 GL1100
Scratcher09
Re: Gettin' Naked
#40
'82 GL1100
Smoothboy
Re: Gettin' Naked
#41
Post by Smoothboy »
Cool look!
'78 GL1000 "Black Bart"
'82 GL1100
'97 Magna
Abilene, Tx
Re: Gettin' Naked
#42
looks good. you don't need the weight in the bar ends anyway. goldwings don't vibrate
Scratcher09
Re: Gettin' Naked
#43
Just got my hands on a set of wheels from an '83. I don't like the look of the comstars. The bonus is the previous owner had put new Honda bearings and new Dunlaps. I'll post pics when I get them installed.
'82 GL1100
Re: Gettin' Naked
#44
Are you still planning on the dual headlamp? Bars look good, but that was a lot of work but welding looks to be easy for you.
Scratcher09
Re: Gettin' Naked
#45
I am still planning to go with the dual headlight. I will need to put all the wiring under the faux tank because there is not much room in the dual buckets. I'll tackle that soon.
'82 GL1100
