MotoNudo Build
Lads
Re: MotoNudo Build
#31
Post by Lads »
All the bowls were swapped.
Had to change my numbers
Re: MotoNudo Build
#32
Well if only the bowls, that is a pretty good PO. Many do much worse. Shocks are pretty important to handling, I would not use worn out stuff or leaky air stuff. There are several good alternatives, Hagon, etc.
Lads
Re: MotoNudo Build
#33
Post by Lads »
Nozzle and jet holder were filthy. All of them looked like this.
Also had a broken tower
But I don't think it will cause any problems
One of my pilot fuel tubes was turned 90 degrees from the intake and one of the flanges on top is broken.
Not sure what to do about it.
Re: MotoNudo Build
#34
you will need to take out and turn the pilot tube
Lads
Re: MotoNudo Build
#35
Post by Lads »
Thanks rcmatt. Is it threaded? One of the top flanges is gone.
Re: MotoNudo Build
#36
No, it isn't threaded. You will probably need to warm the carb body to get it to move. Broken like that is usually when someone tried to turn it or remove it and it is "stuck" in the body.
Lads
Re: MotoNudo Build
#37
Post by Lads »
Done. Tapped it out, gently. Thanks for the info.
Going to solder and redrill the idle ports per Randakk's tech note. No #62 bits laying around so I will finish the rest and wait for the drill bits I ordered.
Valve lap and water pump are next.
Lads
Re: MotoNudo Build
#38
Post by Lads »
Don't think these are salvageable. I wanted to get them shinny but they are very etched. Might need to paint them.
Re: MotoNudo Build
#39
Those will shine up real purty.
Lads
Re: MotoNudo Build
#40
Post by Lads »
How many hours? Seems like some other posts I saw took a long time. Sandpaper first? Wire brush on a wheel? I have seen posts on polishing but not with this deep etching.
Re: MotoNudo Build
#41
Most use aircraft paint stripper first. Some use fine sand paper, but it doesn't take long to use the colored polishes, coarse to fine. I can't really see from pics, but often the etching is just through the clearcoat.
Re: MotoNudo Build
#42
as for the pilot tube, meant also to say that randakk actually has replacements as well
Lads
Re: MotoNudo Build
#43
Post by Lads »
I will work on them with stripper. In the meantime, I took the intakes off the "stock" GL1000 and noticed they are different. Here is a pic. Any idea which is the legit intake? Look at the flange relief and the depth of bolt shroud.
I also noticed the rubber part has 19 on one and 15 on the other.
Lads
Re: MotoNudo Build
#44
Post by Lads »
P.S. They both had the 755A designation on the carb body
Re: MotoNudo Build
#45
I have a box of 30 or more. The inside diameters varied greatly. I am not sure which is best. They may have gotten mixed up from various years. Bigger isn't necessarily better. I think some of the larger openings leave a ridge around where they meet the head, which can't be good, but it's hard to see looking down the elbow. There were also some aftermarket elbows made, usually they were chrome. The chrome ones I had were bigger.
