When I was rebuilding the Yamaha, I tried more methods than I can count to fix leaking calipers. I finally broke down and found replacement calipers on E-Bay.
I tried to circumvent that whole process on this build. Oh, the RH slave cylinder is cracked and leaking? I won't even attempt a repair -- I'll jump straight to "replace it." Except what I received was a LH slave cylinder on a RH bracket, grrr. Fine. I'm having problems with the fittings leaking on the LH slave cylinder, so I'll move the LH that's mounted on the right side to the left bracket, and order another RH caliper from E-Bay.
However, the "1978 GL1000" brake caliper I received, isn't. It's very similar, which has me wondering if it's from a GL1100, maybe, but the bore of the cylinder is bigger than that of my old GL1000 cylinder.
Here's a photo of the caliper assembly:
...and the "new" caliper's piston, compared to a real GL1000 piston:
So...the hunt continues for a REAL RH caliper that is actually from a '78 GL1000
(P.S., if anyone can confirm what this caliper might actually be from, I'd appreciate it -- I'll probably put it up on E-Bay myself)
Rebuilding isn't a problem -- I've rebuilt all of the calipers I've tried. The problem is a crack inside the cylinder wall on one, and a leak around the bleeder valve (from the threads, it looks like) on another.
About the only way to fix them, as far as I can tell, is to weld them. The one with the leaking bleeder *might* be repairable by replacing the bleeder with a plain 8mm bolt and crush gaskets, but I'd really prefer to have a brake that I can bleed properly.
maybe it is from a 79, they are different than a 78
-Rodger- all it takes for evil to prosper is the want of a few good men to do nothing-Edmund Burke The question is not how much time do you have, it is what you do with the time that you haveGandalf "One of the greatest dignities of humankind is that each successive generation is invested in the welfare of each new generation." Fred Rodgers "it takes 10,000 hours to become an expert" ancient saying
rcmatt, thanks, I wasn't aware of that. I knew the '76 and '77 models were different than the '78, but I didn't know the '79 was, too. I'll keep that in mind while searching for a brake that works. In the mean time, I'm gathering up quite a collection of miscellaneous, old bike parts!
mwallette wrote:rcmatt, thanks, I wasn't aware of that. I knew the '76 and '77 models were different than the '78, but I didn't know the '79 was, too. I'll keep that in mind while searching for a brake that works. In the mean time, I'm gathering up quite a collection of miscellaneous, old bike parts!
Always good to have 'stuff' ......
yeah, I call it the "pile O'parts" I think Redwood calls it my stack of junk
well.... I have stacks.... sort of sorted.... but if I have an unexpected outcome... she will trust all my friends here to sort it out
More "stacks of stuff" on the way. I could only find a lh/rh pair of '78 GL1000 brakes on E-Bay. Thought I might be able to score just a RH brake from the brother of a friend, but the ice on the roads up here in Alaska is melting quickly and I want to ride as soon as my driveway is clear*.
Once the brakes get here, I'll disassemble, clean and rebuild...again.
"New" brakes have arrived, and I managed to get yet another RH cylinder cleaned, reassembled, and reinstalled on the bike. I now have enough pressure in the front brakes to stop the bike while rolling in the garage...once I pump them up (so there's still air in there somewhere). I'm letting them sit for a few days to look for leaks; if I don't find any evidence of leaks, I'll try bleeding them again :crosses_fingers:
On a more positive note, I managed to come across enough funds -- and spousal approval, lol -- to pick up the new shocks I wanted. Hagon 2810 TTSA's on the way! Should make for a nice 2-up ride.
As cliched as it sounds, I've decided to mostly black out the bike, so on my to-do list: remove the crash bars, passenger grab rails, fenders, and clutch lever, clean them, and paint them with either black roll bar paint or the Dupli-color Blackout Shadow paint that I used on my XS750 tank. The plastic shelter covers and side covers will also come off, get sanded down to bare plastic, have the Honda and GL1000 emblems removed, and be painted satin black. I've got a spare set of wheels, so I most likely won't touch the wheels already on the bike, but will probably paint the spares in the future.
I'll have to do something with the mirrors, too. Aesthetically, they don't work, and, since they are pretty much the same as the mirrors on my wife's CB750, I'm not optimistic about them functionally, either. I'm the road captain in the group I ride with, so being able to see what's happening behind me is important (the only reason I didn't go with bar-end mirrors, like I did on my XS750). I've got a couple of ideas in mind, but...later. Let's get it running, first.
One other question for the gurus: when I first started the bike, after it had been sitting for a year (-ish -- I don't know how long, exactly), there were a few drips from the water pump. The last two times...nothing. Is that "normal" or should I proceed with my plans to replace water pump gaskets? Was it just lack of use, or is this a warning that I should address before it really becomes a problem?
I've had the water pump weep hole drip a bit after sitting over the winter. Other's too I believe. Rather normal as long as it stops.
