1976 GL1000 - "The Phoenix"
kjmarti2
Re: 1976 GL1000 - "The Phoenix"
#31
Post by kjmarti2 »
I had quickly reinstalled the engine after the fasteners and paint were dealt with, but when reattaching the clutch cable I had issues turning the wheel (I later found out that was just normal clutch drag). So I then decided to install a new clutch. It wasn't necessary at the end of the day, but I'm really glad I did. I ordered a new Barnett set and went to town. I got most of the job done in the frame by removing the rear wheel but I couldn't get the old gasket off, so I removed the engine AGAIN. I then buttoned everything up, installed the engine again and when I got the newly coated exhaust I was ready to start reassembling things.
Yellow 1976 GL1000 - "The Phoenix"
1976 GL1000 LTD
2002 CB900F 919
kjmarti2
#32
Post by kjmarti2 »
Things moved pretty quickly from here. I got the carbs back from Mark Boody and the crash bars back from the chrome shop so I started putting everything back together. When I started replacing cables I saw that I was probably pretty close to being stranded somewhere on the side of the road :shock:
The radiator install was a giant pain. The replacement hoses I bought were super tight and took incredible strength to get into position, even with vaseline. My arms hurt for days afterward. It was a struggle to get the top clamp at the upper hose into position as well.
1976 GL1000 LTD
2002 CB900F 919
kjmarti2
#33
Post by kjmarti2 »
The bike was back together, but there were a few loose ends to tie up. The gauge cushions were extremely cracked and ugly so I replaced them with GL1100 units. I also wasn't getting any power to the starter so I replaced the killswitch and found yet another fastener issue.
Once that was fixed I started her up and she ran great! At least until the coolant leak started..
1976 GL1000 LTD
2002 CB900F 919
kjmarti2
#34
Post by kjmarti2 »
Turns out that stock clamp at the upper hose was deformed, so I replaced it with a different style clamp and it worked great.
I added a tank decal, and the rest is history.
1976 GL1000 LTD
2002 CB900F 919
kjmarti2
#35
Post by kjmarti2 »
Looking forward to enjoying her now and reaping the benefits of all my hard work. We're at generation 3 now for this bike, here's to the next one!
Thanks for reading and for helping me along on this project. This is a great forum, especially for newbies like me.
-Kyle
1976 GL1000 LTD
2002 CB900F 919
Paola Zago
#36
Post by Paola Zago »
Kjmarti2, you did an incredible job, and you declare yourself a neophyte ?? you were very good and you did a wonderful job! On this site you do crazy jobs on the GL, you are not professional mechanics, but simple and true fans! I am always speechless, I would like to thank you all one by one, for all that you publish and I absorb like a sponge, but that I will never be able to do! I take advantage of this post to send an applause and a hug to all of you!
Paola
#37
It is a 1976, but could those be either 76 LTD or 1977 handlebar? It was a popular mod back in the day. Great documentation of the restore.
kjmarti2
#38
Post by kjmarti2 »
Thanks Paola, I appreciate the kind words! As I'm finding on my LTD work, every project is different and so I feel like a newbie all over again :lol:
Fred, yep they are '77 handlebars. My Dad had those installed by Pete as he wanted a bit more upright riding position. I had intended to replace them with a '76 set, but decided to keep them for now because they are pretty comfy.
1976 GL1000 LTD
2002 CB900F 919
#39
Great read, and nice work!
JAG
Brass Member
Brass Member
#40
Post by JAG »
Love the write up. Glad to see her restore. Love the yellow!!
kjmarti2
#41
Post by kjmarti2 »
It's been a while since I've posted a status on my GL1000 projects. When I last posted about the Phoenix I assumed that I was done with the really hard work and could enjoy it for a few years with just basic maintenance. lolol :IDTS:
After a bit of a honeymoon period enjoying the Phoenix I had to pull it offline a few months ago for a few reasons. #1, the mpg I was getting was way too low - about 22 mpg. I actually was left stranded on the highway because of it sometime back in the late spring, luckily I was close enough to a gas station that I could wheel it there myself. After a good bit of detective work I found out that cylinder 4 only had 65# of compression and the other 3 cylinders had in the 115# range. I think the actual magnitudes of those numbers are a little suspect because the starter isn't in the best shape but the difference was enough that I knew something was wrong. But it wasn't a blown head gasket or anything so I kept riding it with the intention of doing something about it in the winter. Then I blew a head gasket..
1976 GL1000 LTD
2002 CB900F 919
kjmarti2
#42
Post by kjmarti2 »
I finally got around to pulling the heads a few days ago. Here's a few pics of the left head.
The tops of the pistons look pretty clean to me to be almost 45 years old. I haven't inspected the cylinder walls yet but I'm not expecting any issues. The left-most intake valves are from cylinder #4 which is the one that had low compression. It turns out the exhaust valve was bent.
The right head gasket was blown. A few pics below.
The right head was super easy to remove and a ton of coolant spilled out when I pulled it. You can see that the #3 valves have a good bit of coolant on them, and the top of cylinder 3 has lots of carbon buildup. I'm not sure if that is just due to the coolant leak or if I had a bad valve seal that leaked oil, or if it was running really rich. Could be all 3 I suppose.
I've got all the valves removed and will be sending both of these heads off to be rebuilt. In the meantime I will be cleaning up the pistons and the block, and then turning my attention to the water pump which needs replacing.
1976 GL1000 LTD
2002 CB900F 919
#43
Geez Louise!
number 1 cylinder wall appears extremely eroded from the corrosive effects of water . :shock:
kjmarti2
#44
Post by kjmarti2 »
gltriker wrote: Mon Dec 07, 2020 11:35 pm Geez Louise!
I had to go out and look. I didn't look in there when I pulled the head and I couldn't see it well on my phone, but blown up on my computer it looks like there's a lot going on in there. I think it's just a reflection of the cylinder head on the wall. I just snapped another pic and looked in there and it looks pretty good. Whew!
1976 GL1000 LTD
2002 CB900F 919
