Thanks Barrie
Advise on which looks better please...
- JonathonCranny
- My Album: https://myalbum.com/album/h3GKgpMuqLZQ
Re: Advise on which looks better please...
"Worrying about things is like sitting in a rocking chair, it will give you something to do but it will get you no where"
- JonathonCranny
A riders paradise indeed Dean
- 77Gowing
"Less is More" Anonymous
77Gowing
1977 GL1000 "O'le Blue." (sold
2014 Yamaha 950 V Star (sold)
77Gowing
- 230Rocket
Jonathon,
So I think robin1731 means the corners that I've marked in the attached photo. It they are radiused, there's less chance of them developing cracks over a period of time with the vibrations from road use.
cheers
Dean
cheers
Dean
1982 GL1100 Fat Turtle
yes, sorry I missed the question asking for clarification.
Here in Winnipeg, Canada, they use photo radar to catch speeders or red light violations. I had a similar setup (first photo) and was told to change it. It was a bit skyward, but easily readable from the back from stationary cameras which are 7-8’ in the air, but mobile units cameras are on the front number of cars, so it probably wasn’t able to be captured.
It might be worth the trouble to inquire of legalities. I fixed mine, went to court with the revision photos and they waived the fine.
Do those rear shocks work normally when they are angled forward like that ?
- JonathonCranny
Thanks mate that makes perfect sense, I'll have to try and add something for stability as I would need to remake to hole the thing to get radiused on those strips.
- 77Gowing
Gord,
I often think the same thing everytime I see the shocks on my Indian scout, they lean way forward.
And they are factory.
With my numb butt, I would not know the difference.
77Gowing
77Gowing
Ideally they would be angled at the same angle as the swing arm. Anything else is a compromise. Anywhere on the arc of the swingarm
would be the best
would be the best
- JonathonCranny
Getting there, just need some paint on it..
Those Kellermann Atto indicators are incredible.
- JonathonCranny
Thanks for the advise mate you were spot on so I've welded some edges on those sections. It worked out really well as they made a channel to hide the indicator and licence plate light cablesrobin1731 wrote: ↑Sat Aug 22, 2020 8:13 am Looks good. I do have one thing to point out. The area that you cut out. Where the bend is. It would be better to make the inside corners with a radius. Less potential for cracking that way. When doing work like that I drill a hole, maybe 1/4", at each corner and then cut to that.
Thanks again mate.
- Jonesz
You do nice work JohnathonC
Jonesz
1979 Suzuki GS850. Sold
Nicely done!
- JonathonCranny
