How did you connect the two (fused and unfused) wires to the starter relay? Originally they were crimped together in a common ring terminal. Did you do this, or connect them separately (two ring terminals) to the post on the starter relay?desertrefugee wrote:Electrically, mine is the same now as it was when it left the factory. The only exception is that now there is fresh wiring and a 30A blade fuse in line where the dogbone used to be. (The charge side wire is still unfused).
Main Fuse and wiring
- mryellow
- Lead Member
Re: Main Fuse and wiring
It doesn't really matter, whichever is easier for you. I used two ring terminals.
