GL1100 Cheap E-Z Single Carb Conversion
dkl
Re: GL1100 Cheap E-Z Single Carb Conversion
#316
Post by dkl »
Know the problem,,,I'm look'n at a 84 V65 Magna......If I pull the trigger should keep me out of trouble till next summer.
cuyler1
#317
Post by cuyler1 »
unique carburetion i found through my valued youtube and what's really funny is all the forums i belong to! ngw,gw facts,gw docs,gw riders, and after learning so much: hogforums,streefighters,suzuki-gsr,kaw,yam and mostly of importance to me homemadetools.net forum. and all these forums refer to others and it is contagious. unique carburetion has been shown to others by me 100's of times. without your thread DKL i would still be converting stock airboxes with aluminum plates and jb weld as pictured in some of my first threads. since then i've called all the customers and now friends back and have used your method to swap out (some didn't want to) the old builds.can't wait to do an 1800! i have been busy converting 50cc scooters to 80 or more cc and working on boring and stroking a 1500 a friend of mine has that drove it without water for two months last winter. it didn't die , he just kept complaining that the temp gauge wasn't working. i added some water to it andddd
bmwhacker
Zinc Member
Zinc Member
#318
Post by bmwhacker »
Moved it over to another thread. "Weber DFT 32 conversions"
Living Proof you shouldn't play with matches.
A certified "Boxer" fanatic:
Goldwing's, BMW's, Zundapp's,
cuyler1
#319
Post by cuyler1 »
beautiful, bmwhacker! i'm really interested in the carb and plenum. please tell what type 32/32(dfa?-afg)?,plenum, where can one obtain it,jetting and vacuum line connection placement . MORE!
cuyler1
#320
Post by cuyler1 »
something else, i've been wondering about john schmitt and his conversion as i'm doing my brownie(84 1200) at this time also. john are you still there? and merry christmas too all!
John Schmidt
#321
Post by John Schmidt »
cuyler1 wrote:something else, i've been wondering about john schmitt and his conversion as i'm doing my brownie(84 1200) at this time also. john are you still there? and merry christmas too all!
Yup, still here but my single carb conversion isn't. While working with it I was also scrounging up the various missing parts to the OEM set up. I eventually got them all together and ordered the rebuild kit from Randakk along with the manual which turned out to be invaluable to me. I got the OEM's done and mounted but discovered an oil leak from the weep hole at the water pump. So....on to that repair(new water pump) which I just completed. It's all back together now so I'm now shopping for some gauges to build a carb sync kit. Hope to do something with it this week, would like to get it running again even without a sync which I can do later. Just getting anxious to move past the engine and complete the rest of the build.
1998 Valkyrie Tourer, my Honda Davidson ;) Image
dkl
#322
Post by dkl »
Shops been to cold to work on anything,,,,,,but ready to ride. I hate winter......
#323
dkl wrote:Shops been to cold to work on anything,,,,,,but ready to ride. I hate winter......
You're in Louisiana right?
#324
Looks like the " winter " may be taking a break for the next few days. Enjoy
77Wing
#325
Post by 77Wing »
At one point, on my way to work this morning, the temp display in my Blazer showed -13.
#326
77Wing wrote:At one point, on my way to work this morning, the temp display in my Blazer showed -13.
Pretty sure your not in Louisiana :lol: :lol: :lol:
#327
-34f here Monday morning. Plus 24 now. We might break freezing tomorrow. It's a welcome relief. I turned in my papers saying I'm retiring the 28th of May. I hope this is my last winter. Not much getting done on my Wings.
dkl
#328
Post by dkl »
Yes, I'm in Bayou State, I do feel guilty when I'm complainin' about a high of 40 degrees........but dang it, that's cold to a Louisiana Boy.
#329
dkl wrote:Yes, I'm in Bayou State, I do feel guilty when I'm complainin' about a high of 40 degrees........but dang it, that's cold to a Louisiana Boy.
LOL, yeah I was thinking 40's or even 50's. High here the last couple of days was single digits. Upper 40's right now and I'd be in a t-shirt. lolol
dkl
#330
Post by dkl »
Busted out of garage to test run camping modifications on bikes. Found an Ethanol Free station on the loop. Planin a camping trip for Easter Weekend. Everything working great.
