x
Re: Maybe I'll call it Threedom?
#331
Way to follow orders my friend. Quite an accomplishment for sure. You should be proud!
Sandy
#332
Post by Sandy »
action1 dancr anim-cheers1
x
#333
x
#334
Sounds like a keeper for now. Perhaps the valve timing is just a bit better with the added lash. Who knew?
x
#335
x
x
#336
x
x
#337
x
Sandy
#338
Post by Sandy »
My GUESS would be:
using 12 volts, as that would give a higher calculated amperage:
60 watts / 12 v = 5 amp
12 v / 3 ohm = 4 amp x 2 coils = 8 amps
Total 13 amps on that circuit.
I'd fuse it at 20 amp with #12 wire size as feeder conductor.
Just a guess.
x
#339
x
Sandy
#340
Post by Sandy »
gltriker wrote:Thanks Sandy! My results were 13amps too, but I couldn't find anything to state what fuse rating minimum would be appropriate.
Rule of thumb, maybe not automotive I don't know, I've always used maximum load of a circuit is 80%.
x
#341
x
#342
Continually amazed ....
Gord(here's to you buddy)Jones anim-cheers1
'13 Honda NC700sa … TNG
x
#343
x
#344
Great engineering once again Cliff. See you at the fairgrounds this time...
#345
Excellent seeing you and the trike briefly at Pete's and linger at the fairgrounds. Safe travels back to NY and may your return be less eventful.
