The building of "Bones"
duke182
My Album: http://ngwclub.com/gallery/v/wingmans/duke182/
Re: The building of "Bones"
#346
Post by duke182 »
Hoosier Daddy wrote:X3
............clean up the casting flash, especially around the oil drain back holes at the bottom of the heads.
good advice here too.
getting rid of the flash will help oil drain back and will also help eleviate stress and protect from cracks if you decide to hammer on it occassionally after you get it rideable.
great progress rainstromrider, btw i am enjoying watching this build as you get closer to completion.
1984 1200 standard
click pic to see my gallery
vote in my poll
#347
Great to see the progress Nate. Hope you get her started soon, so that the final issues can be discovered early.
rainstromrider
#348
Post by rainstromrider »
Got the message on the heads boys! Cleanup and go, besides I have my hands full getting the rough cast outside smoothed. Did get the heads, and valve covers stripped last night. Valve covers have some nasty corrosion on them! Thought I would cleanup the valves on my lunch break today, but the crud on the exhaust might as well be ceramic! Makes sense it is baked on pretty hard. Took half an hour on 1 valve!
Fred Camper wrote:Great to see the progress Nate. Hope you get her started soon, so that the final issues can be discovered early.
There will be no problems! I'm an optimist to a fault, my wife calls it "Nate land" :)
Thanks, Still a long way to go. Wiring will be fun fly into a rage
Daily rider...
2012 Concours 1400
Projects...
81 1100 "Bones" (Stripped!)
Maintain...
Uncle's 76 1000 (for sale)
rainstromrider
#349
Been busy! Just a dry fit for a quick pic, but it helps keep me motivated!
Don't know what came over me, but I had to smooth the valve covers. One of them was really nasty. Took me a couple hours to get all the pitting sanded off.
Love how the heads just flow into the block now :orange
Full frontal dancr Can't wait to get the cooling system parts and the cam pulleys and tensioners done!
Stay tuned fly into a rage fly into a rage fly into a rage
Daily rider...
2012 Concours 1400
Projects...
Maintain...
#350
Nothing like progress to keep motivation up. How is the wiring going, love the engine!
#351
You know that engine is going to be way to pretty to put in a bike??!! ;)
Hoosier Daddy
#352
Post by Hoosier Daddy »
I
AM
IN
AWE!
(Jaw hits floor)
rainstromrider say's I'm "addicted to the build"... I think he might onto something :)
rainstromrider
#353
robin1731 wrote:You know that engine is going to be way to pretty to put in a bike??!! ;)
Because of that, I did find online some VHT clearcoat. Only 7-8 bucks a can. Definitely going to clear it!
Daily rider...
2012 Concours 1400
Projects...
Maintain...
gregforesi
#354
Post by gregforesi »
I used VHT white on my engine. It turned very yellow in 200 miles. I had to pull the engine again for another problem so I repainted with Duplicolor engine enamel. It still looks good after a year and 4700 miles.
Without the carbs on it that engine looks REALLY wide.
2006 GL1800 (Brutus Maximus)
rainstromrider
#355
gregforesi wrote:I used VHT white on my engine. It turned very yellow in 200 miles. I had to pull the engine again for another problem so I repainted with Duplicolor engine enamel. It still looks good after a year and 4700 miles.
I've found duplicolor engine, but not clear? I'm not particular to any namebrand if anyone has a suggestion? And it does look quite wide on it's own!
Daily rider...
2012 Concours 1400
Projects...
Maintain...
rainstromrider
#356
Don't know if the photo was worth the attempted hernia, but I couldn't resist seeing it in the sunlight
dancr Image
Hoping to have the water tubes and cam pulleys done tonight. Probably won't have head gaskets and timing belts till next week, but I'll have everything finished and waiting.
Fred Camper wrote:Nothing like progress to keep motivation up. How is the wiring going, love the engine!
No wiring at all yet. Once the engine is back in, and before the carbs go back in I'll start on the wiring. All the electrical system is going on the back of the acrylic panel for the gauges. I'm going to ditch the tach to make room for the misc parts. They will all be semi-polished, or painted in copper.
Daily rider...
2012 Concours 1400
Projects...
Maintain...
#357
Nice, and will look good in Da Moonlight too.
Are the carbs runners? Are the runners semi polished? Does...
Bama Jama
Lead Member
Lead Member
#358
Post by Bama Jama »
Valve covers look good. I like the smooth look.I'm building 5hp Briggs and smoothed all the flasning and seams on the block.(Too much time on my hands and not enough $)
Bill
Montgomery,Al
rainstromrider
#359
Fred Camper wrote:Nice, and will look good in Da Moonlight too.
Carbs would be front runners for the ugliest carbs ever right now, nasty pitting on the aluminum, the rubber boots are scarred by the p.o.'s liberal use of a wire wheel, every steel part is severely rusted, and all siliconed together! Not Good! But...I have a plan ;)
Daily rider...
2012 Concours 1400
Projects...
Maintain...
reidransom
#360
Post by reidransom »
rainstromrider wrote: But...I have a plan ;)
From everything I have seen in this thread, this can only turn out completely awesome.
