GL1100 Cheap E-Z Single Carb Conversion
slowbeemer
Brass Member
Brass Member
Re: GL1100 Cheap E-Z Single Carb Conversion
#346
Post by slowbeemer »
I tried both the sae and metric thread gauges and had no luck. Seems to be some odd size. :( Endless searching hasn't netted any gains either. VW guys cut off the plunger if the valve fails but nobody seems to remove it and plug the threads.
dkl
#347
Post by dkl »
In Picture cut-off solenoid is pointed to back of Bike, How will u adjust carb ???? I always point it at side of bike...
dkl
#348
Post by dkl »
My 81 GL1100 running with new version DKL 1" PVC single runner manifold and VW 34 pict 3 Carb.
slowbeemer
Brass Member
Brass Member
#349
Looks like it runs great. I'm getting super excited about mine.
I have some right angle screwdrivers so I'm not too worried about adjustment. I tried to orient the carb with the fuel bowl on the low side of the carb when its on the sidestand. Probably totally unnecessary but I wasn't sure which way you pointed yours. Oh well. I guess I'll just gut the valve and create a plug out of it. Thanks for all your help though!
earthquake
#350
Post by earthquake »
slowbeemer wrote:I tried both the sae and metric thread gauges and had no luck. Seems to be some odd size. :( Endless searching hasn't netted any gains either. VW guys cut off the plunger if the valve fails but nobody seems to remove it and plug the threads.
slowbeemer
Solex carbs seem to have there own thread pitchs, I have tried to find stainless button head screws to hold the top on the body, closest thing I have found is that a 10-32 will work as long as you only thread it in about 1/4". As for the the "fuel cutoff solenoid, the only thing I have found to do is cut off a old solenoid and weld up the hole and either cut a slot for a big screw driver or grind two flats and use a adjustable wrench. I will ask on "the Samba" [a VW forum I hang out on] if any body know of some where to get one.
Casey
"If it shines, bends, bangs or clangs, ITS METAL!!! and if I cant work it, I"ll piss on it!"
I love Boxer engines be GoldWing or VW
http://www.rememberingkelly.com/
slowbeemer
Brass Member
Brass Member
#351
Thanks Casey. I've been meaning to introduce myself on the samba but haven't gotten around to it yet. I just picked up a 72 bug that will be getting the class 11 Baja treatment as soon as the wing is done. :-D
So I took a ride today to a specialty bolt place and the valve baffled the employees. Seems to be a 11mm bolt with a superfine 1.0 thread pitch. Practically a non existent combination. So it looks like I have 2 options. I can drill the carb out to 12mm and rethread it and use a standard 12mm bolt or gut the valve that I have and plug it someway. I really don't want to modify the carb so maybe tomorrow afternoon I'll cut the valve open and see what we have.
socrace
#352
Post by socrace »
M11 is used in a few brake systems, a 7/16 x 24 banjo bolt should fit also.
slowbeemer
Brass Member
Brass Member
#353
So I just fired her up for the first time in 3 years and she ran great. I am really impressed with this carb. I haven't made any adjustments yet, just started up right out of the box. I think it's running a little rich at idle and I don't have my tach hooked up yet so I'm not going to touch it for a bit. But it ran and it ran good. :-D
Big thank you to dkl for posting this manifold. I don't think I would have ever thought about using pvc for something like this. And thank you to everyone else in this thread for posting their experiences.
Here's a quick video of it running. Never mind the rats nest of wiring. Still need to wrap the harness and route it through the frame.
dkl
#354
Post by dkl »
The small screw-volume adjustment- the book recommends 2 1/2 turns out as a starting point, and says to stay in between 2 to 3 turns out on final setting..Using this manifold do not be afraid to open this screw out much more..I opened it up more and it dialed in real strong.
Druid1369
#355
Post by Druid1369 »
Would a set up like this work on an 85 1200 and could you use the same measurements and steps but use other piping choices?
SBFFSB
Druid
#356
Yes
Rockdog
#357
Post by Rockdog »
So I read the whole post.....the good ...the bad ....the dramas.....the lows and the highs.....the best parts are and what I gleaned from all of it.....and by the way...it was a good read.....that I can do this to my 78 gl1000 on the cheap and not really loose any ride time....then I can save up and maybe have the stock ones rebuild later when I've got the big bucks to do that......HOW AWESOME IS THAT!!!!!!?????? And it looks like I can get all the couplers and stuff on amazon prime....except for the pvc pipe itself.....I'll go to ace hardware for that in town ...don't think I'll do any soft lines..... all hard.....I was into air cooled vw's for around 18 years....so pretty familiar with the 34 pic3 carb......I LIKE IT........personally I think this is GENIUS!!!!!! Cheap...easy....if you're a purist......MEH!!!!! I'm riding and you're not......until I can afford to rebuild my oem's.......AWESOMENESS!!!!!!!!!!!!!!!!!!!!...... I think I love you..... man crush....... lol.."here's my bike........my first bike in 25 years.....last bike I had.....I LOVE IT!!!!
sonoramike
Brass Member
Brass Member
#358
Post by sonoramike »
Holy ancient thread revival
OK, I'm in with the DKL manifold
Been playing with these damn carbs for much longer than I'd care to admit, I can sync 2&4, and 1&3 - but can't get left bank sync'd to the right. Runs like crap, idle all over the place. Clearly I still have a problem.
I'm as stubborn as the next fool, but I give
Ordered the $68 34 PICT-3 chinese clone carb off ebay y'day, and am off to Lowe's here in a few to get the PVC to build both versions - the bent pipe (https://www.youtube.com/watch?v=Rl4MNQ_C5S8) - and the version on the prev page with the 22.5* angles vs bending the single pipe with heat
Then see which version I like better, add the 12v tube heaters and insulation to keep em from icing up (IO'll find and add the links to these later on), and get some black paint on - and finally get to riding soon now that fall is here
Got a carb sync kit available and for sale, gently used...
