Water Pump Job
Re: Water Pump Job, 2-Spanner
Robin's kit is for the front cover .... might be able to help tho' ....
'13 Honda NC700sa … TNG
Re: Water Pump Job
Pictures restored in post #1.
KYpondman
Re: Water Pump Job
Thanks Roady, you're a good man!!!
Claude
Claude
leggman
Re:
I used three old longer bolts and threaded them into the water pump and hit the bolt heads with a small hammer. It pushed the pump right out.jstengel wrote:I cannot get the water pump out of the housing. Shall I press it using the three bolts backed out a bit or whack it? What kind of pressure can the shaft take? I hesitate to whack it or press it. I gave it a few "love taps" but now I am seeking advice before going further. Thanks in advance.
Wangthang
Re: Water Pump Job
I used a #3 phillips to remove the tranny. cover screws. I smacked them first with a brass drift, and they came right out. I was actually suprised how easy they came out. I struggled at first with an assortment of tools, but then realised if you push against the screws really hard while turning they come right, even with the screwdriver angled. Going back with Robin's bolt kit.
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
OldRider2
Re: Water Pump Job
Do you need to put gasket shellac or some sort of sealer on the transmission cover and the water pump gaskets or leave them dry?
2008 GL1800 with Motor Trike Conversion
2001 GL1800 Illusion Red (SOLD)
Re: Water Pump Job
I've done 2 water pump jobs and left both dry. No leaks from either.OldRider2 wrote:Do you need to put gasket shellac or some sort of sealer on the transmission cover and the water pump gaskets or leave them dry?
