79 GW EFI Project
rainstromrider
Re: 79 GW EFI Project
#46
Post by rainstromrider »
Great work so far! Take more pics!
Daily rider...
2012 Concours 1400
Projects...
81 1100 "Bones" (Stripped!)
Maintain...
Uncle's 76 1000 (for sale)
kb0ou
#47
Post by kb0ou »
Howdy,
Well, I have never seen a 1500 with fuel injection, all the ones I have seen have 2 carberators.
Then, I have never seen a 1200 with fuel injection nor have I ever seen a oxygen sensor on a 1800.
So, I have never been privaliged to see where they are located.
The microsquirt can function just fine without an oxygen sensor. So I am not too worried about the location of the one I have mounted.
We shall see how it works, if it works. I could not see a better place to put it than where it is. I hope to start connecting everything up to the computer and see how the sensors work while running the carberator before the final switch, that will show me what I am looking at for tuning when on fuel injection.
I will try to take some pictures this week and post them.
See Ya,
John C. kb0ou
1979 Goldwing gave it away... :(
#48
Thanks John, looking forward to further reports.
kb0ou
#49
Post by kb0ou »
dancr
Have not done a thing with the bike, been busy with family stuff and worked on my brother's 55 Ford Pickup.
So, have not taken pictures or anything for a while.
Will try to get out to the shop and take some pictures today and post them, that is probably about all I will be able to do. confused22
It was fun driving the 55 Ford Pickup though, I got to drive it from his ranch to the house in town and then to another shop that is going to work on some stuff. It has a 351 Cleveland in it, it is a blast to drive.!!!!! action1
See Ya
John C. kb0ou :crosso
kb0ou
#50
Post by kb0ou »
type1
UPDATE!!!
Okay, here is a picture or my brand new flange for my throttle body...........
One more..........
And here is a picture of my Elbow modification fixture lolol
Fancy name.............
This is a fixture to help get the injector bungs put in right. dancr
Now to get some holes bored in the elbows to accept the injector bungs and
Work on the manifold to take the throttle body flange.....
Also working on throttle cable mounts to actuate the throttle body.... :guitar
Lots to do
See Ya
#51
Getting there. Still eating popcorn, but pulling for this to work all the way.
badorderbob
#52
Post by badorderbob »
Been following your progress, very good!! Good luck to ya!! Just wish I had the know-how!! Keep up the good work!! Later, hippie1
Robert White
kb0ou
#53
Post by kb0ou »
Hey, I could not sit around this afternoon so I worked on getting ready to weld in the bungs
Here are some picture of my weld stand and sample elbow................. :orange
Just about ready to weld in some injector bungs to the intake manifold adapters (elbows) dancr
By the way, the blue bolt is holding the Injector Bug in place for welding, the bolt goes right through the Injector Bung...;)
See Ya,
LikeMike64
#54
Post by LikeMike64 »
ericheath wrote:Getting there. Still eating popcorn, but pulling for this to work all the way.
+1
I like your jig-work. Excellent idea.
Mike
#55
Are you going to weld it or JBweld?
STREETWING78
#56
Post by STREETWING78 »
Will ya grind the bung out on the inside? or leave it in the stream.
I like this stuff!!!
Tom
1976 LTD #276
1976 BLACK VETTER (soon to be naked)
1978 Naked(soon to be dressed)
1983 750 sabre(1476 miles) next project
1989 1500
1998 cr250
1974 bultaco 250
1973 suzuki tm125
Memphis Twin
#57
Post by Memphis Twin »
STREETWING78 wrote:Will ya grind the bung out on the inside? or leave it in the stream.
I was wondering that.
I think it needs removing as it will seriously impede airflow.
1979 GL1000 Hotrod
1976 Moto Guzzi 850 T3 'Speziale'
1986 BMW R80 Cafe/Bobber (Gone to pastures new)
kb0ou
#58
Post by kb0ou »
To weld or not????????
I just ordered some HTS-2000 Aluminum welding rod (brazing rod) type1
Gonna try it out
So, I may weld the bungs in with the Aluminum magic brazing rod :flamer
The protruding bung, I thought about grinding at a slant before installing (welding) the bung in, I also thought about just leaving it, BUT, I agree it looks like it would reduce air flow into the cylinder some.
Have not decided what to do yet, it will problably not protrude that much when I am done.
Stay tuned.... anim-cheers1
FirstYearDeek
#59
Post by FirstYearDeek »
Definitely need to remove the portion protruding into the intake. Not only will it impede air flow, but depending on the mist angle of the injectors, you're probably spraying a good amount of fuel on the walls of that tube.
-Deek
P.S. That jig is pure genius! Even if the rod doesn't work out, you've solved JB Weld's downfall; movement when curing. Great work!
#60
We look forward to seeing how that magic aluminum brazing rod looks and works. That's what I will try if I can't get the hang of DC TIG with helium. I live at the very edge of the world and it's taking me forever to get some argon/helium gas. I bought a whole lot of intake manifolds to practice on. When I get done I'm going to ask Randall to race. heh heh
