click here:
viewtopic.php?t=79374#p833813
Shade Tree Single Solution by HOTT
Re: Shade Tree Single Solution by HOTT
#46
Not cheap, but rising rate fuel pressure regulator be able to do it? I have been exploring the turbo side, and this is what they use. I've been looking at blow-thru carbs , but it appears this could be done for supercharged setups. They can be adjusted from zero to many psi. Set it at three psi and it will boost psi 1:1 as you add psi of boost. Reference line from below supercharger signals regulator regulatory add psi to inlet to carb. Maybe 1:1 is too much? Excess from electric pump is returned to tank. You guys are probably way ahead of me, but maybe I'll learn something new.
cbrianroll
#47
Post by cbrianroll »
Hey everyone. Why not revive a great thread!!
My project has sat way to long…. Time to get at it now I hope. I was thinking dual carbs but I think I want a single now? This was the last topic I was reading and was wondering if there are updates or thoughts on it. Or is there a better solution I should look into?
78 gl1000 rat project thingy...still under construction
76 gl1000 parts for 78? Trying to get running...
#48
Post by HOTT »
Wow ! there's a blast from the past. Thanks.
I still have 3 bikes that use this set-up. I found to be less finickee,and is less effected by unleaded gas.
Perfect ? No. Just a pretty good alternative that can get a 'Wing back on the road.
Carb of choice is Weber 32/32. It's been awhile I don't even know if you can find them anymore.
You can experiment with different carbs single or 2bbl are easiest.
I have 1 that still has a 32/34. It works well and has an intake noise you wouldn't believe. lol
The manifold works best without the fan baffle plate (behind the rad) and or by plumbing water or oil underneath...
cbrianroll
#49
Thanks for the update! Guess I’ll start looking for a carb!
