78 Scrambler
Easter
Re: Tracker style
#46
Post by Easter »
Necessity is the mother of invention (and new found mechanical skills)!
83 GL in process :IDTS:
ronajon
Re: Tracker style
#47
Post by ronajon »
thanks to the holidays i finally got time to work on the bike.
after the scavenger pump rotor issues, i put on a set of 2nd hand gl1100 carbs. the seemed out of sync, so bought a carbtune. Still the carbs were running not in sync, so took them apart, cleaned out every jet and put the carbs together. Unfortunately i broke on of the idle adjusters, but descided to put the carbs together anyway (mainly because i had no other adjuster anyways)
at first startup the revs went directly up to 3k rpm, and wouldn't idle at all. first thought was i forgot tho clean out one of the jets.
After fiddling with the throttle cable, the revs went down.
throttle response was terrible, but the bike ran. So grabbed the carbtunes again, and finally after synching she runs great. Superb throttle response, no backfiring, steadly idling.
today i went to the parts shop and found a replacement cable for the backlight and some nice bar-end mirror.
ronajon
Re: Tracker style
#48
Post by ronajon »
found time to do some small modifications
- drilled the front discs
- swapped the footsteps with motorcross pegs
- swapped the passenger footsteps with bmx pegs
- changes tires to Metzeler Tourance
Markn
Zinc Member
Zinc Member
My Album: http://031sink.blogspot.nl/
Re: Tracker style
#49
Post by Markn »
Tires look awesome on it! (Any chance that you are familiar in the dutch bmx scene, couse of the pegs?)
ronajon
Re: Tracker style
#50
Post by ronajon »
Markn wrote:Tires look awesome on it! (Any chance that you are familiar in the dutch bmx scene, couse of the pegs?)
no, i'm not familiar. reason why i put them on was last week my son wanted a ride on the back and i had no passenger pegs.
after some searching i stumbled on his bike and saw the pegs on the front. he doesn't use the front pegs on his bike, so now they serve a purpose.
BigDub
Re: Tracker style
#51
Post by BigDub »
Brilliant peg maneuver there! that's my kind of style.... great build. are those old tyres or new? i like the duel sport look to them. Although as heavy a bike as these GL1000's are i suppose they will shred thru a set of those pretty quick?
thanks in advance.
1984 VF1100 Flat Black Saber
1981 GL1100 Flat Black Bagged aka my pickup
1976 MR175 farm/trail bike
1975 GL1000 Antares Red
ronajon
Re: Tracker style
#52
Post by ronajon »
BigDub wrote:Brilliant peg maneuver there! that's my kind of style.... great build. are those old tyres or new? i like the duel sport look to them. Although as heavy a bike as these GL1000's are i suppose they will shred thru a set of those pretty quick?
thanks in advance.
thanks, the tires are brand new, so i hope the don't wear out too fast :)
i just ordered some heat wrap, i'm planning to wrap the exhaust pipes, leaving the mufflers as they are
Smoothboy
Re: Tracker style
#53
Post by Smoothboy »
Nice ride!
'78 GL1000 "Black Bart"
'82 GL1100
'97 Magna
Abilene, Tx
Re: Tracker style
#54
Sure looks like a sweet ride. Are you sure you want to wrap those pipes, been told two years maximum from wrapped pipes due to accelerated corrosion?
ronajon
Re: Tracker style
#55
Post by ronajon »
Fred Camper wrote:Sure looks like a sweet ride. Are you sure you want to wrap those pipes, been told two years maximum from wrapped pipes due to accelerated corrosion?
i read about the corrosion also. perhaps i'll try painting the headers first, then see how i will look and decide if i'm going to wrap it anyways
cafewing
Lead Member
Lead Member
Re: Tracker style
#56
Post by cafewing »
I love what you did with it, it looks great.
What is that seat originally from?
oldwings 78
Re: Tracker style
#57
Post by oldwings 78 »
The rear fender looks great. Did you cut off a section from the forward end of the original fender or is that off a different bike? It's interesting how much of the bike is still original while changing the look so much. Nice work. I would say the word(s) for the look of the bike should be elegantly ballistic. Good job!
Terry
"A man who is good at making excuses is rarely good at anything else" Benjamin Franklin
"A man who will sacrifice freedom for security deserves neither" Benjamin Franklin
'78s are the best looking GLs Just ask Doc
ronajon
Re: Tracker style
#58
Post by ronajon »
cafewing wrote:I love what you did with it, it looks great.
the seat came from a Triumph Speed Triple. I "borrowed" the idea from Octane's Bulldog, and have seen other GL1000's with that seat on this forum.
oldwings 78 wrote:The rear fender looks great. Did you cut off a section from the forward end of the original fender or is that off a different bike? It's interesting how much of the bike is still original while changing the look so much. Nice work. I would say the word(s) for the look of the bike should be elegantly ballistic. Good job!
Terry
thx for the compliment!
i did cut off a peace of the original rear fender. i especially wanted to keep the lip of the fender. If you look closely, you can see some hole in the rear end, where the original mudflap was attached
for the rest i try to use as much parts from scrap yards, or parts i had lying around already.
ankof
Zinc Member
Zinc Member
Re: Tracker style
#59
Post by ankof »
really nice looking bike. hard to tell what it is that makes the difference, but some bikes just got it.
1976 GL1000 Sidecar Scrambler
ronajon
Re: Tracker style
#60
Post by ronajon »
just got back from a test ride. doing 140kmh sitting straight up, with no windscreen is not much fun ... but test passed
