WINGIPEDIA - GOLDWING WHEELS 1975-1984
Re: WINGIPEDIA - GOLDWING WHEELS 1975-1984
Yes, I would think a thread called Triple tree fork mods would be cool.
- 82aspy
ngw quotes
ngw quotes
- 82aspy
i'm going to just add a few intermodel wheel swaps 'possible mods required' (within the wing line)
haven't got to my 82 yet though can confirm that 1100 interstate discs bolt on to a 84 16" front wheel that has been modded to an 83 1100 front
so stock 18" to (1200) 16" front wheel for 83 1100
http://www.goldwingfacts.com/forums/2-g ... e-iii.html
ngw quotes
ngw quotes
yeah, Im going to profile brakes next. thanks.
- 82aspy
i was mulling over including brakes with the front end thread, but no doubt it could be a topic in itself
ngw quotes
ngw quotes
I plan to open a new thread and do it the same wiki style, with pictures and facts.
- 82aspy
rear end swingarm pumpkin/diff wheel swaps
1100 swingarm to 1000 is out there
1200 to 1100
http://www.goldwingfacts.com/forums/2430585-post21.html
http://www.goldwingfacts.com/forums/1679273-post13.html
1200 to 1100
1500 wheel/diff into a 1200 swingarm scenariosI am using the 84 swing arm, rear drive and wheel, axle assy, and the brake support, and shocks (for now as they are 1" longer - 13 1/2" as oppesed to the 12 1/2" on the 82),. keeping the caliper from the 82. I had to make another spacer to go in between the caliper support and the swing arm. I didn't measure it as there is quite a bit of leeway in the axle end. Not a lot of clearance between the tire and the gas tank, bit looks to be ok.
http://www.goldwingfacts.com/forums/2-g ... ssues.htmlTo install a 1500 final drive into a 1200
To install the 1500 final / wheel with bigger double row bearing / and larger brake
ngw quotes
ngw quotes
- 82aspy
pretty sure a modded front comstar
http://s690.photobucket.com/user/tigera ... sort=6&o=8
ngw quotes
ngw quotes
- Norbert R
That's Wittmann's "Malevolent" bike, you could ask him direct
- 82aspy
one of the pix in the above link shows a comstar front on malevolent
here's a 1200 rear diff/wheel modded into a 1000 swingarm
http://www.goldwingfacts.com/forums/1044150-post10.html
http://www.goldwingfacts.com/forums/1045556-post13.html
ngw quotes
ngw quotes
- Hoosier Daddy
Here are my polished '81 reversed Commies, although off of my CB750 build I think the same would apply to our GL's...
schwarz633
- Tin Member
Is there a companion thread to this one that covers the interchangeability of wheels between different model years? I'd like to know for instance, is it possible to run the 1983 cast wheels on a 1977 GL1000. Or is it possible to run the 1977 laced wheels on a later model.
Basically, without serious modifying, the rear wheels from GL1000 and GL1100 are not interchangeable. The front wheels can be interchanged, however it requires shimming and brake system mods to do so.
- 82aspy
1100 swingarm in 1000 frames has been done as well as 1200 swingarm in 1100 frameschwarz633 wrote:Is there a companion thread to this one that covers the interchangeability of wheels between different model years? I'd like to know for instance, is it possible to run the 1983 cast wheels on a 1977 GL1000. Or is it possible to run the 1977 laced wheels on a later model.
forget the details now as far as diffs goes, but the 1200 swingarm allows either a 1200 wheel combo or 1500
spoking comstar wheels has been done
pretty sure there is also a 1200 wheel/diff combo mod in a 1000 swingarm
there are front end swaps 1200 -> 1100 -> 1000, some bolt on, another needs small mods
prob another thread with all the possible combos and what you are after exactly
ngw quotes
ngw quotes
Anything can be done, like I said, with major mod.
