viewtopic.php?t=79155#p830592
Erector Set/Treasure Hunt aka Benelli Dynamo
Re: Erector Set/Treasure Hunt aka Benelli Dynamo
#46
Had a snowstorm today, so after I had the drive cleared I decided to work on the bike a bit. I cleaned up the wiring and reinstalled the components.
#47
You did some nice detailing on them wires. I like it.
#48
Ordered a new piston and rings. I got the first oversize and dropped it off at my friend Tom's house last night. He has a buddy that will have it bored out for me. In the meantime I got some other parts and my wish list is dwindling. I got the wheels and tail light cleaned up, primed and final coat of "chrome" paint. Not concours work, but not bad either. I think it will be a 5 to 7 footer.
I also took the carb apart. It did not look too bad. I am sure glad I cut my teeth on the easier Goldwing carbs before attacking this bad boy!
#49
More progress. Waiting on tires, cylinder bore and a few other small parts.
#50
Fine work Sir .....
Gord action1
Casper
#51
Post by Casper »
Whoa, that carbs waaaaay to complicated for me, must be 30+ parts in that monster.
Glad your on the job, not me.
Nice Work!
#52
Looking more like a mini-bike! Should have rims and new tires on sometime this week.
#53
I got my tires and throttle grip today. This is the first time I am going to attempt to mount tires on the rims. For every other project I have had someone else do it. The tires are the same for front and back. The tread does not appear to have a forward and back. There are no arrows on the tires indicating direction. Is there a correct direction to mount the tires on the rims? Stupid that I don't know, but I really want to do it right the first time. Thanks for the input. ernie
#54
With those tires there is probably no difference. If there were they would have an arrow on them. Do those take tubes? That is where you may have trouble.
I use armor-all cleaner as a lube on the bead. Don't use soapy water.
#55
Tires are on! Piece of cake. (I wont mention that rims that come apart make it SLIGHTLY easier).
Next I can work on the throttle/brake unit I got in the mail today.
#56
Found a right hand brake/throttle assembly that I did not have to mortgage the house for, received it, cleaned it up and realized it was slightly different than the original. After a little bit of work with the dremel tool and a 9/64 drill, PRESTO!
I then worked on the front brake at the business end. I could not figure out why the tab on the shock would not extend into the brake hub. Thought about it and could not figure it out. The rear one worked fine. Last night at 3am when I was up as usual, I wondered if the front and rear hubs are the same. NOT! The spacer is about 1/4 inch longer on one. So when I get some time I need to change front and rear.
#57
One of the seat cover rivets is rusty ......
Gord anim-cheers1
#58
RAT wrote:One of the seat cover rivets is rusty ......
Gord anim-cheers1
LOL! You are one of a kind!
#59
It might be PATINA ?
Gord anim-cheers1
#60
I took the time to swap out the brake units. All is good!
I also put together the front brake light mechanism. I did not realize that Rube Goldberg was Italian!
