The Cost of a Decent Paint Job
- wingless1
Re: The Cost of a Decent Paint Job
dry time and cure time are very different. Dry to touch means the solvents (water is a solvent) have outgassed for the most part. Cured means the chemical reaction in the polymer has finished (for the most part).
Both are heavily affected by temps, humidity, baro pressure and application thickness, thinner types used, amount of thinners used, even the gun used can affect performance.
Assuming that the painter did everything right, as mentioned above (-and it's a big assumption) the dry and cure time can be roughly calculated from the material data sheets that the painter should have, or at least the dealer they bought it from should have.
I have sprayed activated and accelerated acrylics that dried ready to mask in 1/2 hr and were 80% cured, ready to buff, in a couple of days, but they were brittle and hard: chipped easy, no flex on plastic surfaces, so would peel, and got hot enough during the initial cure to scorch the masking paper! (used an accelerant called "Japan Drier" to allow multi colours applied in one day). I have sprayed urethanes that took overnight to dry and weeks to cure to 80%. Have sprayed enamels, put on very thick at owner's request, and against my recommendation, that took weeks to dry beyond a skin and many months to cure.
Epoxies, acrylics and urethanes are pretty consistent as long as they are mixed with the right components in the right ratios-but in small paint shops, that often doesn't happen-you run out of medium acrylic reducer and grab the medium urethane and then everything changes (had a 50' line from a 2 gal pressure pot get "lined" with a 1/4" string of hard plastic in seconds, from mixing a water-based urethane with an acrylic high speed reducer one time).
So, to answer the op question: totally possible that it is still soft-and may be for a lot longer.
You can speed up the cure with heat: several days at high temps (uncomfortable room temps, about as high as you can go without melting parts) will speed things up. You're in Phoenix, so the temps are probably fine for paint cure, so wait a couple of months before washing it or abusing it>
1975 GL1000, '13 beta 300rr, '? ct110, '82 kz440ltd, '84 vf750f, cm185t
gone and missed: xs650, cb650sc, ts400, drz400s
- theburgundian
It's a good stuff for only $200
For my last bike (LS 650 Boulevard/Savage) I paid €300 for a gloss black with ivory stripes.
If you want to change the color, think about Plasti Dip next time, maybe it will be ok for another project
Always look on the bright side of life buddy
Have you done this?theburgundian wrote:It's a good stuff for only $200
The cost of the special equipment looks $$$.
78 GL1000 Original Owner 131k
- theburgundian
Another member here have done it.
It's not expensive, Plasti Dip exists in spray, don't need any compressor.
This product is employs by car tuners and there are good feedbacks using it.
the post is here
http://www.ngwclub.com/forum/viewtopic.php?f=16&t=54943
the post is here
I thought I was the only one who knew about Japan Drier. My Dad always had some in his shop to add to oil based house paint to make it cure faster & tougher. I don't use it in acrylic enamel but I always do when I am using oil based.
Most people don't know as most people never use oil based paints in their home.Sidecar Bob wrote:I thought I was the only one who knew about Japan Drier. My Dad always had some in his shop to add to oil based house paint to make it cure faster & tougher. I don't use it in acrylic enamel but I always do when I am using oil based.
There is something in latex paint that bothers me. Just the smell of it makes my stomach turn so I can only use it outdoors or with really good ventilation so I prefer to use oil based whenever possible. I also use a urethane based rust paint for Eccles and always use Jap Drier in it, especially when I spray it.
I love using oil based but it is a pita to clean up.Sidecar Bob wrote:There is something in latex paint that bothers me. Just the smell of it makes my stomach turn so I can only use it outdoors or with really good ventilation so I prefer to use oil based whenever possible. I also use a urethane based rust paint for Eccles and always use Jap Drier in it, especially when I spray it.
- theburgundian
you also can use acrylic paint mixed with silicone base, but you might be a very good painter to have a nice result. I made it in the Inside of my luggage, "to hide the misery" as we say in French, but the result is not ugly and the luggage is waterproof.
- Irishman1
I did my wife's free 75 back to as close as I could come to anteres red without buying the vmr paint. They wanted $79.00 per rattle can or more for pints. I used duplicolor resto red and clear acrylic. $5.00 per can x 5 cans
In the garage:
1975 Honda gl1000 sulfur yellow( my first!) NGW BOTM February 2020
1975 Honda gl1000 red (Ruth's free bike) NGW BOTM January 2017
1975 honda gl1000 red. Eariest of my 75's 2/75 date
1975 Honda gl1000 blue green 5/75
1975 Honda gl1000 blue green 3/75
1975 Honda gl1000 blue green 4/75
1976 Honda gl1000 sulfur yellow
1977 honda gl1000 red black, Ian's next bike
1976 Honda gl1000 red next restoration
1975 Honda cb750 rebuilding soon!
1975 Honda gl1000 2/75 blue/green
1978 Honda cb750f super sport
1979 Honda cb750f super sport
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
"I really need a BIGGER garage!!"
"I got a bigger garage!!!!
" ride'm, don't hide'm!!!
1979 Honda CBX
1980 Honda CBX
1981 Honda CBX
- tomk1960
Wow - looks awesome. Nice job!Irishman1 wrote:I did my wife's free 75 back to as close as I could come to anteres red without buying the vmr paint. They wanted $79.00 per rattle can or more for pints. I used duplicolor resto red and clear acrylic. $5.00 per can x 5 cans
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
Looks great from here but how hard is it and will it chip easily?Irishman1 wrote:I did my wife's free 75 back to as close as I could come to anteres red without buying the vmr paint. They wanted $79.00 per rattle can or more for pints. I used duplicolor resto red and clear acrylic. $5.00 per can x 5 cans
- theburgundian
Great job you've done. Congratulations.
I have found that rattle can paint jobs hold up great----if you leave them in a dry heated room for around five years.
The rattle can green I had on Mr.H for 14 years held up pretty well.
