I'm trying to purchase carb vacuum barbs locally. The motion pro brass ones are $11 on amazon prime but is like to get them sooner. Apparently, 10-32 thread fit 5mm just fine.
Help: Runs worse after timing
- groupus
- Location: Lancaster Pa, USA, Earth, Solar System, Milky Way
Re: Help: Runs worse after timing
The pilot screws are not broken, but adjusting them in and out does nothing.
Faster, faster, faster, until the thrill of speed overcomes the fear of death. ~Hunter Thompson
every now and then, when things are not going to well in the shop, i ask myself why i do it. and the answer is that riding is good....but time in the shop is also good. - CYBORG
78 gl1000 cafe build: http://ngwclub.com/forum/viewtopic.php?f=30&t=51461
79 full fairing - current status: Haunted http://www.ngwclub.com/forum/viewtopic.php?f=1&t=60334
That usually means idle circuit and or pilot jet is plugged.groupus wrote:snip.............The pilot screws are not broken, but adjusting them in and out does nothing.![]()
Carbs need to come off and get cleans.......that's what it will take to fix the problem
- groupus
Not that I won't end up tearing the buggers off and cleaning them all over again, but I find it hard to believe because I have cleaned these carbs 3 times, prodded all of the orifices with wire, polished, dipped, boiled, you name it. AND it did exactly the same thing with the other set of carbs, which i pulled apart after and there were no obstructions to be found. I cleaned my rebuild-able fuel filter and installed a second in-line filter before putting the fresh carbs on. Now I know how Sisyphus feels.
There is a theory about folks who do the same thing over an d over, expecting different results . It sounds like a carb problem,....but maybe not
Maybe give someone else a shot at cleaning them
Yeah, the symptoms you describe point to idle circuit obstruction 99%, or more, of the time. Sorry.
And if so, a look inside the tank is warranted. Use a mirror and look at the top of the tank. They can look great on the lower 3/4 of the tank and be covered in rust on the top.
