GL1100 Flat Tracker
Re: GL1100 Flat Tracker
#46
Post by HOTT »
.002 ! action1 action1 action1 action1
nice demo. :orange
hmratbam
#47
Post by hmratbam »
This is the fan mount with an and blade removed as it is on the radiator.
This is the fan mount with the motor mount removed.
The Upgr8 12V Slim w/mount kit 7" fits snugly inside the fan mount.
The 6 mm flange nuts filed flat on 2 sides fit in the mount slots on the fan,one is already in place. There will be short bolts threaded into these through holes drilled in the side of the mount.
I think it's gonna work!
My Album
84 Standard ongoing project
hmratbam
#48
Post by hmratbam »
Mystery item,what is it?Hint: it is in the first picture above.
Opposite view of mystery item.
I don't want to confuse the issue,but I have been working on Goldwings for about ten years and never saw one of these before!
My Album
hmratbam
#49
Post by hmratbam »
This is what all those pieces in a previous post look like all welded together exhaustively ground(I told you I'm not much of a welder!) and mounted on the engine.
Yes,a Quadrajet carb will fit in there.
Still have to make a base for the air cleaner element and hook up the throttle and choke cables but as they say about Prego Spaghetti sauce" it's in there!"
My Album
#50
Exciting stuff there Ron.
#51
Post by HOTT »
hmratbam wrote:Mystery item,what is it?
Is that a cover for the hose clamp mechanism ?
They pop up in odd places in my shop.
Neat fan mod. Keeps the look. :orange
Easter
#52
Post by Easter »
I have seen one or two of the rubber clamp covers but usually they haven't survived the forty years of maintenance these old bikes have been subjected to.
83 GL in process :IDTS:
BikeMaine
#53
Post by BikeMaine »
Mystery item on here right?
Kevin
1982 GL1100A
hmratbam
#54
Post by hmratbam »
Actually it was on the other clamp. Didn't mystify anyone,just showed how far out the the sticks I am!
My Album
hmratbam
#55
Post by hmratbam »
This is an attempt to show how very fragile the connections to these LED indicators are. My first attempt to build the panel ended with several of the wires broken.
You can see my somewhat crude solution to the brken off connections-a blob of silicone!. Also the second attempt went better with considerably less wrassling the whole thing around during assembly.
The final result.The stock ignition in the stock location protrudes thru the large hole,the small holes are for bolts that hold the panel to acouple or flat bar mounts that utilize the stock holes for the gauge cluster and also provide the upper mount for the front number plate. This pretty much concludes the electrical. The last test had all necessary features like headlight,signals, spark at the plugs and cranking when the start button was pressed.The 1100 fuse block,spark units and regulator rectifier mount to the right side of the shelter frame. I'm using aftermarket controls so the front section of the loom is changed with a lot of wiring finding it's way to "spare parts".
My Album
#56
Panel looks good. I have a couple of the rubber covers in my "rubber stuff" drawer. But could not remember where they came from
BigBrian27
#57
Post by BigBrian27 »
I LOVE the fan mounting solution. I hope you don't mind me stealing that idea.
1975 Honda GL1000 Goldwing
1992 Kawasaki Concours ZG1000
Solid rotors suck! I have the PDF for the rotor drilling template, PM me if you would like a copy.
#58
Im not clear on how you mated the 1000 pumpkin to the 1100 driveshaft. Did you have to cut both sides off? Man you move fast!.
hmratbam
#59
Post by hmratbam »
To mate a 1000 pumpkin to an 1100 driveshaft,you have to hold your mouth just right and think only good thoughts. Seriously you don't do anything different than installing an 1100 pumpkin,that part fits just fine.The 1000 final bolts to the 1100 swingarm and the driveshaft fits w/o mods.You have to lengthen the other side and change to shock mount. What you weld on the end of the lengthened swingarm is dictated by what rear caliper you use. On this one I used the 75 caliper on the Bopper I used an 1100 caliper which involves some spacer switching. I think Hott addressed that in one of his builds.
I don't know about "moving fast",seems like I've been working on this thing forever! When I've a project going I do little else because I don't HAVE to. I'm retarded(no job),single and have no obligations except eat and sleep.
My Album
#60
No kidding.... All this time I've been assuming otherwise, which, in turn has held me back from putting spoked wheels on my 1100 project. Dang. Thanks captain Ron!
