All in (with tires) I am at $2,125.
I went with new brake lines up front and made a world of difference but was worth the extra $
1983 Interstate Custom Build
- BikeMaine
- sgwilly
Re: 1983 Interstate Custom Build
Nice job on the paint. I hate you.
Because I can't paint.
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
Thanks guys.
- Tin Member
I’m also converting an 83 Aspy to a Cafe-Cruiser.
Did you remove the steering weight and relocate the electrical box in order to install headlight mounts? Where did you move the electrical to, and how was is to to move?
I removed the weight. All the original wires/connectors are in the headlight bucket. It was a pretty tight fit but is all went in.
- Tin Member
Ah ha! Of course, the headlight! Thank you so much, I’ve been toiling with this question since the beginning!
- Rusty Probie
A beautiful oneisualum wrote:Starting a new thread to document my second Goldwing build.
First Build - 1982 Aspencade
viewtopic.php?f=15&t=64093 Rachat de crédit
I wanted to go with an 1983 to get to the aluminum wheels instead of buying switching later. I learned a lot on the first one and wound up doing some items twice. I had set a budget of $1500 for this one - if I do tires, I more than likely will go over a little but it is a goal. Will keep track as I go.
As I found it - 1983 Interstate - $500 clean title
Losing some weight and assessing any damage - so far it is only fork tubes that are bent and the instrument cluster is busted up.
Good place to start, looks like a solid bike. Hope you can get a good deal on some forks.
