1985 GL1200 Limited, time for a new project.
Rednaxs60
Re: 1985 GL1200 Limited, time for a new project.
#46
Post by Rednaxs60 »
Nice work on the rims. Going to look very nice.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
Wolfie666
#47
Post by Wolfie666 »
Bit of a major screw-up...
When I built my last 1200, I used dual webers, and made these port matching spacers for the manifolds...
but, I also sectioned the tank cover, well, for whatever reason, I didn't change the new tank cover and even
wothout the adapters the carbs wont fit... time to do some creative thinking!
Wolfie666
#48
Post by Wolfie666 »
Made the air deflectors from the GL1100 fit the 1200.
Easter
#49
Post by Easter »
And people said my project (Red Belly) had a lot of red! Looks great! Really nice job with the paint.
A curious thing happened on my project, shelter and tail were painted at the same time from same gun over the same epoxy primer and looked the same when cleared but after 'cut and polish' the shelter was noticeably darker. Not sure of the cause but it is back to the booth for me.
83 GL in process :IDTS:
Wolfie666
#50
Post by Wolfie666 »
Easter wrote:And people said my project (Red Belly) had a lot of red! Looks great! Really nice job with the paint.
Thanks. Yours looks really good as well! That's odd, if the same base was used it should all be the same.
Wolfie666
#51
Post by Wolfie666 »
Starting to look like a MotorCycle!
Rednaxs60
#52
Post by Rednaxs60 »
Accent pieces going to be black? Need another colour to break up the red and accent the bike.
Ernest
2008 GL1800 (sold)
Easter
#53
Post by Easter »
Rednaxs60 wrote:Accent pieces going to be black? Need another colour to break up the red and accent the bike.
People paint their bikes all black all the time. Why not all red? Go for it. (but them I may not be an unbiased commentator.) devil1
Wolfie666
#54
Post by Wolfie666 »
I painted this one black, and felt it was time for a change...
Gl1100, 1200 engine, 1200 front and rear suspension.
BikeMaine
#55
Post by BikeMaine »
I like all the red, it's different, which makes it great.
Kevin
1982 GL1100A
Wolfie666
#56
Post by Wolfie666 »
A little more work today...
Going to slow down as the weather gets colder...
My wife tells me I can't run the garage furnace until I finish putting up the ceiling.
and that was back in 1994!
Wolfie666
#57
Post by Wolfie666 »
Found an oil seal for the front wheel when eliminating the speedometer drive and replacing it with a custom spacer...
Wolfie666
#58
Post by Wolfie666 »
Catching up on some progress...
Molded in the front frame section
Made this little headlight bracket.
Made brackets and mounted the steering damper.
Used a Virago front fender, bolted to a heavy fork brace I made.
The Oil Seal I found, and the spacer I made to eliminate the speedo sender.
Wolfie666
#59
Post by Wolfie666 »
The fork brace
Made this brake line splitter to unlink the brakes
BikeMaine
#60
Post by BikeMaine »
Great progress man.
Kevin
1982 GL1100A
