*Accident Repairs / Fork Swap* 75 Wing Cafe RestoMod
Re: *Accident Repairs / Fork Swap* 75 Wing Cafe RestoMod
#511
Honda had a brake dust guard on many of their bikes in that era .... that’s what the hole was for ....
Gord(got one somewhere)Jones
'13 Honda NC700sa … TNG
Hanslehoff
#512
Post by Hanslehoff »
RAT wrote:Honda had a brake dust guard on many of their bikes in that era .... that’s what the hole was for ....
Just looked them up...I had no idea that even existed. Don’t think I’ve ever noticed one on a bike before...lucky it was there, really simplified my task
GW Hobo
My Album: https://www.ngwclub.com/forum/viewtopic ... it=GW+Hobo
#513
Post by GW Hobo »
It's just a great looking bike with a lot of clean mods. Speedo on back is another of many good ideas I may steal Hanslehoff. Getting close now.
1982 GL1100 Cafe - Born Naked
2020 October BOM
Hanslehoff
#514
Here we go...
Hanslehoff
#515
GW Hobo wrote:It's just a great looking bike with a lot of clean mods. Speedo on back is another of many good ideas I may steal Hanslehoff. Getting close now.
Thank you, steal away! anim-cheers1
5speed
#516
Post by 5speed »
that is a nice looking gasket, seal kit.
good luck..it's not a difficult repair job.
Hanslehoff
#517
Got the water pump all installed no problem. Front end looking good with new paint and bolts
Fresh oil, fresh coolant, turned the key on, hit the start button and....nothing. Not a click, nothing. crying1
Headlight dims like it should but nothing else happens. Everything else is getting power and is working perfect. I’ve never had any issues with it before and as far as I can tell everything is hooked up correctly and nothing is missing. I’m frustrated and at a bit of a loss where to start to solve this
Buli
#518
Post by Buli »
Looks good.
Kinde
#519
Start with main fuse. If still a dogbone, they can be cracked and hard to notice. See if it turns over with the kick starter or a wrench. Try a jumper cable from the battery positive to the lug on the starter to confirm starter is good. Check battery cables and main ground lug behind the engine hanger. With your recent paint work, it may not be making a good ground. I have had the glass buss type fuses appear perfect, but the metal ends will spin giving intermittent contact. All minor checks. The other item that comes to mind is to check the right angle connector at the base of you key switch since you redid the forks. It may be loose or failing.
Rednaxs60
#520
Post by Rednaxs60 »
Like the black on the oil filter and water pump inlet, looks good.
Did you do the pump with the engine in the bike?
Cheers
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
Hanslehoff
#521
Rednaxs60 wrote:Like the black on the oil filter and water pump inlet, looks good.
Cheers
Thank you. Yes I did the pump with the engine in the bike. Wasn't too difficult other than getting the gasket material off the engine case was a bit of a pain having to work around the frame members and basically lying on the floor.
Hanslehoff
#522
ericheath wrote:Start with main fuse. If still a dogbone, they can be cracked and hard to notice. See if it turns over with the kick starter or a wrench. Try a jumper cable from the battery positive to the lug on the starter to confirm starter is good. Check battery cables and main ground lug behind the engine hanger. With your recent paint work, it may not be making a good ground. I have had the glass buss type fuses appear perfect, but the metal ends will spin giving intermittent contact. All minor checks. The other item that comes to mind is to check the right angle connector at the base of you key switch since you redid the forks. It may be loose or failing.
I'll try turning the bike over by hand today and make sure it's not hydro locked (even tho petcock has been off). I checked the dog bone and all the connections at the battery yesterday as well as all the fuses. My ignition is no longer stock and I have redone all the connectors...so either I've mixed a wire up somewhere or something has gone bad during the last 9 months its been sitting on the lift. I am going to pick up a multi-meter today and see if I can track it down. Most frustrating part is I did almost the exact same re-wiring and front end work on my buddies cx500 and his started right up this week
Hanslehoff
#523
Moral of this story: be careful when wrapping and rerouting wires...if you pull too hard 43 year old solder might give up.
Got it soldered back together and she started up with minimal persuasion. Have a check list of things to go through and double check(did I torque this, did I fill that, etc) and then it’s maiden voyage time!
Hanslehoff
#524
First little shake down went great. Brakes and suspension need some fine tuning, but in what little time I was on she sure felt good. One thing I have yet to figure out is the tach setting for the Acewell. It has the options of 0.5, 1, 2, 3 or 4. Haven’t been able to find what it needs to be on for a GL...any ideas?
5speed
#525
Post by 5speed »
anim-cheers1
