Meet Ol' Sparky
kanada
Lead Member
Lead Member
Re: Soft-tail '83 HOTT SL
#61
Post by kanada »
OH... I get it. That is very ingenious. action1
JRK5892
#62
Post by JRK5892 »
WOW!!!! man that is crazy very nicely done!!!
Joe
Chicago, IL
#63
I don't know how I came to be moderator of this forum. "I'm not worthy!!!"
#64
Post by HOTT »
Thank You!! Here's a little gas tank work I did;
I traced the rear down tubes on to the old tank and cut....
While open I glass beaded the inside. -Observation-the best way to clean a rusty tank is to cut it in half :-D
From here I wrapped the opening with sheet stock and began spot welding. I'm MIG welding this whole project so I use this method to keep from distorting the thin sheet metal.
'Death by a thousand spot welds' (the small tube pass thru is for reserve)
This is how it will sit in the frame. Since this photo I added a 1/4'' return at the filler and a 3/8'' barbed outlet. This tank will be used in tandem with a spun aluminum (oil tank replica) tank. The stock petcock will work as normal. I finished the inside with POR-15. Capacity will be approx. 3 gal.
on to the seat and rear fender......
#65
have you done anything about a fuel gauge?
#66
Post by HOTT »
I was thinking about doing a transparent view tube. I'm going pretty lean on the dashboard, so hadn't planned on a gauge. Not too worried with reserve. I'm always open to ideas.
#67
no ideas. was looking for some myself :lol: :lol: on my tank i was able to use a float type sending unit. but only in the lower unit. half of the fuel is in the up-per unit. so i go forever on full, and then to empty in a short time. i still use the miles, odometer, but i do like a gauge
#68
i have concidered an LED row of lights, different colors , that indicate level. easy to build. easy to hide. don't know just yet
ttk85
Brass Member
Brass Member
#69
Post by ttk85 »
that is awsome, when you get done you might find a bunch of goldwing frames on your doorstep waiting for a rear suspension and rake job! great job!
1982 GL1100I
#70
Looks awesome! Three gallons seems to be a stretch. Sure enjoying your pics of this build.
#71
Post by HOTT »
i have considered an LED row of lights, different colors , that indicate level. easy to build. easy to hide.
Easy for you. lolol Sounds cool.
:lol: :lol: I could think of worse things. :lol: Thanks
Yeah, but you don't know how big of a fuel line I'm using. :twisted: I'll measure it out and let you know.
Larrycole
#72
Post by Larrycole »
You could use an 18" diameter fuel line, that would increase the capacity lolol
07 Suzuki C90 "Brutus"
Another 81 GL1100 standard named "Take 2"
81 GL1100 Cruiser project "80-1-2-3" underway OOPS had to start over
Owned in the past
Numerous Japanese dirt bikes
Kawasaki H-1
96 CB750
86 GL1200 SE-I
70 Triumph Bonne
69 Husky 360
74 Suzuki Water Buffalo[/b]
01 Kawasaki KLR
#73
The fuel gauge on a stock wing is for entertainment purposes only, so what is the big deal without a gauge. As long as you have a reserve and watch the miles, all should be swell. This is once great build to follow.
Kwixdraw
#74
Post by Kwixdraw »
First time I have visited this thread. I thought you were going to make a long distance tourer out of the '83' instead of this Radical Custom. WOW
81 Naked resto/custom - INFERNO Cruiser ....complete frame up restore -DONE, BOTM July 2011
Newly aquired 84 std. Nekked
2008 Honda ST1300 - Gives the freedom to ride anywhere in the world without worry,
77 bagger, been garaged and sitting since 1985, Work in progress
#75
the fuel gauge on my 78 works perfect. and with my memmory what it is, the gauge is more then for entertainent. some of us travel in places that don't have a gas station every mile or so
