Dark GreenWing 1977
codyjames707
Re: Dark GreenWing 1977
#61
Post by codyjames707 »
ericheath wrote:If you ever have the motor out again and want the kick start feature, ( It has saved me a few times) you can pull the back cover from your 77 and install it on your 78. Option is also there to swap 77 cams in. If you have 75-77 carbs, they'll probably be happier using the 77 cams.
I had no idea! That is HUGELY helpful to know, the Kickstarterhas been the only thing really making me not LOVE the 1978 engine. Thanks for the info Eric!
1977 Gl1000 DARKGREEN-WING
BOTM April, 2018
viewtopic.php?f=16&t=59710
#62
I haven't done it, so maybe a search will pull up details that will be helpful.
codyjames707
#63
Hey everyone! Little progress moving along here, but any progress is good progress! I found a guy on craigslist who was selling a seat that was custom made for him, but turned out to be too big for his cb550. Luckily the goldwing is a BIG bike! I made the deal, brought the seat back to see how it fit and it is near perfect fit!
BOTM April, 2018
Sugs
#64
Post by Sugs »
Looking good man!
_______________________
'79 Honda GL1000 Goldwing
wheeliedog
#65
Post by wheeliedog »
Some very nice lines starting to evolve here.
Good stuff Codyjames anim-cheers1
warhead_71
My Album: https://www.ngwclub.com/gallery3/index. ... _71?page=2
#66
Post by warhead_71 »
That seat looks like it was made for your GL. Are you planning to add a rear fender or go without?
hornetjo
Brass Member
Brass Member
#67
Post by hornetjo »
Wow the rear is really coming along, great progress!
codyjames707
#68
Hey Everyone! Long Time, no posts! Just wanted to show what I got done yesterday..
I have the solo seat, but I just needed to secure it to a seat pan properly. I decided to do some at-home welding and make some bracing for the rear of it, so I did some card board cut outs to get general measurements. The only thing I forgot to anticipate was the rise of the seatthe further it goes back.
Here was the genereal process:
THEN I BEGAN WELDING ONTO A STOCK SEAT PAN
As you can see, I made bracers for each little panel to make sure they're sturdy.
Then I welded on small little 2 inch squares to the bracers and then welded on the nuts that the bolts will connect to.
BOTM April, 2018
codyjames707
#69
And then I connected the bolts and it was a pretty clean fit! I will be adding some irrigation tubing to the welded ribs to pad the metal and dampen any shaking, then a little 3 inch long piece of square tubing to secure the front, fresh paint and it'll be all good!
Not the prettiest thing, but it will all be covered anyways!
BOTM April, 2018
BikeMaine
#70
Post by BikeMaine »
Looks good, using those bolts?
Some stainless pan-heads would look pretty good.
Kevin
1982 GL1100A
Gowing
#71
Post by Gowing »
Just re read all your posts, good work,
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
codyjames707
#72
Gowing wrote:Just re read all your posts, good work,
Thank you GoWing! I've been slow at it, but it is coming along. Unfortunately when I mounted the seat to the bike, it seems to be sitting a bit too high for my taste; so another round of fabrication starts!
BOTM April, 2018
codyjames707
#73
It is time for me to start thinking about headlights, and I was wondering about some of your inputs on what would work..
I'm not trying to spend too heavy on a headlight set, but these seemed to be in a nice simple middle ground. Wondering which ones you guys think would work best, or if you guys have any personal experience with these change outs.
Here are my two options I am thinking about (Links Provided):
https://www.amazon.com/OSAN-Motorcycle- ... motorcycle
OR
https://www.amazon.com/Speed-Headlight- ... motorcycle
Both seem good to me, but I am curious for some input!
BOTM April, 2018
#74
Here's my first impressions.
From both Amazon listings:
The first light assembly ships with an H4 35w bulb. The lens is PC. I suppose that is Polycarbonate? Perhaps the $19 price reflects that a higher watts bulb would damage (melt?) the lens. Plastic bucket, too.
The second light assembly ships with an H4 55/60w bulb. No mention of lens material, but I'd have to believe it isn't PC.
Has a Metal bucket.$59.
Cliff ;) )
codyjames707
#75
gltriker wrote:Here's my first impressions.
Yeah, the first was defenitely the "eh" one. Any suggestions on an aftermarket headlight? Im at least trying to get the back end of it to be black and not all chrome...
BOTM April, 2018
