Quick update on the electronics assembly. Printed using throwaway junk filament but good for fit testing and mock ups. Fasteners are on the way as well, but you get the idea. CDI boxes mount to the rear, loom it all together and you have a neat little package. Second iteration of the control box will include a slit on the bottom side to allow for a 1/16" stainless sheet steel square to sit underneath the m.unit, housing it from potential RFI interferences. Good point, and after consideration I think it would be worth at least making an attempt to shroud the m.unit. I've read that steel is the best insulator, so we'll go with that. Might not be necessary, might not do jack in terms of protection, but we'll do it anyways.
New industrial printer, new interest in printing parts. Will be changing out the aluminum bellcranks on the carbs for some wear resistant nylon bellcranks, and doing more playing around with ideas.
Next Generation 81' GL1100i
- DCSparrowhawk
- Zinc Member
Re: Next Generation 81' GL1100i
_______________________________________
I like my 'wings how I like my women...
Naked, Greased up, and slathered in honey mustard...
2006 V-Max 1200
2006 M109r Boulevard
1981 Gl1100 Goldwing (Daily)
1983 GL1100 Goldwing (Project)
2006 V-Max 1200
- DCSparrowhawk
- Zinc Member
Updates photos of the electronics assembly with fasteners and bits assembled. This assembly will mount to a cubby hole under the faux tank where the OEM carbs/airbox would be.
2006 V-Max 1200
2006 V-Max 1200
