Big Red, the "Parts Bike"
Re: Big Red, the "Parts Bike"
She is looking good for sure. Great progress. Might look at valve clearance if you still have that side to side issue.
tory
The next day I get in the garage, I will go through valve lash. Thanks. I assume carbs should be re synced after that?Fred Camper wrote: ↑Sat Dec 09, 2023 6:56 pm She is looking good for sure. Great progress. Might look at valve clearance if you still have that side to side issue.
1978 GL1000
1986 GL1200 Aspencade
With California Sidecar
1965 CA95 Benly
1965 CA95 Benly
do not forget to lash those valves.... (desperately trying to make a joke)
tory
Mostly all together. I have a couple loose ends and details to attend to. Still get a little popping at idle and decel. Wondering if the straight through HD mufflers, and lack of cross over could be related.
Even with the flat seat and low bars, it's actually a comfortable ride
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
- puddleduck
- My Album: http://www.ngwclub.com/gallery/v/wingmans/puddleduck/
Looks Great!
Did the same handlebars and other cosmetics. Changed the exhaust and also now have the popping at deceleration and Idle after warm. Let us know how it goes. ( I also have to do a carb sync)
Nice work!
FWIW, I had the same exhaust setup on my '76, no crossover, etc and had no issues. These engines are fairly immune to changes opening up the exhaust. My 2 cents...
I have Ducati exhaust on my78, no cross over, no issues
tory
I recall that bike and it sounded great.
I've gone back through carburetors. Verified valve lash. Reaffirmed carburator synchronization and timing.
It does have new points/condenser as well.
I did notice a tiny spark in the points but very minimal. I am considering trying another condenser.
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
Condensor are cheap. Worth a try. My 78 is still going strong, even with half a million miles on it, but is currently going thru a "freshening up". Mostly cosmedic.
tory
Excited to see that! Work has had me your way more this year. I will have to hit you up next ti.e I am up there and see if you are available.
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
Anytime. You are always welcome. My shop is small...but cramed with some intereting stuff. Holland isn't that far from me. My main exit south takes me thru Holland a lot. On 31 ofcourse. Got the gilmore show coming up soon. You planning on going?
tory
Not sure I will make Gilmore this year.
1978 GL1000
1965 CA95 Benly
1965 CA95 Benly
Congratulations on winning the May Bike of the Month. Great build with the "Parts Bike".
Congrats on BOTM! Great accomplishment!
Congrats on BOTM!
