75 project - "Pete"
Re: 75 project - "Pete"
#61
Do be careful with Rustoleum. Since it dries slow, dust can find its way and also to quick on a top coat can cause a run. I would use it too however as the slower drying yields a better surface finish. Even rolling it or brushing it can yield a brush stroke free surface with good equipment.
pidjones
#62
Post by pidjones »
Frame is finally wire wheeled, primed, and painted with Rustoleum Appliance Epoxy (which is actually an enamel). A few (dozen) more items to de-rust and paint, then some assembly can begin.
3KidsinAustin
#63
Post by 3KidsinAustin »
Was the engine also painted in the Rustoleum Appliance Epoxy? My 84 waiting in the wings for its turn needs the engine dropped to replace the stator, so a good time to pretty up the 21k engine.
Any pictures of your progress? Looks like you've been moving along!
1986 Aspencade (SOLD): viewtopic.php?p=829477#p829477
1986 SE-i (SOLD): viewtopic.php?p=831425#p831425
1984 Interstate: viewtopic.php?t=79359
pidjones
#64
Post by pidjones »
The engine is painted with Duplicolor Engine Paint in and aluminum that very closely matches the original. POR15 is a great engine paint, but any of their metallics leave serious brush strokes (their engine paints are all brush-on). I painted a custom GL1000 with POR15 MG Maroon and it came out great! I've really not made the progress that I'd like. Need to get busy getting the rest of the rust off of misc brackets, etc. and prime, paint them. They will all be primed with Duplicolor (or Rustoleum) etching primer (both lacquer-based) and then painted with Rustoleum Appliance Epoxy (which is actually an enamel). The wiring is all cleaned up, and the carbs were cleaned and rebuilt a couple years ago. I've been a bit stalled out due to health issues, but things are coming around. Still need to order a a new seat cover (I have an excellent seat with just a small tear in the cover). Keeping an eye out for an affordable decal set. I won't paint the plastics until it has been on the road and I'm satisfied with it. They come off easy, and I'll probably paint them with RS Bike Paints water-based and clear coat over.
3KidsinAustin
#65
I've used the same aluminum paint on some aluminum intake manifolds, just to pretty them up. Still have a partial can somewhere on the back shelf. I bet that maroon engine turned out pretty slick. I wish I was better at colors - I can look at something and think "wow, looks great" but never come up with the right combination on my own.
Easter
#66
Post by Easter »
pidjones wrote: Mon Jul 07, 2025 4:46 pm I've been a bit stalled out due to health issues, but things are coming around.
Things move a little slower for us old timers but my moto is "live till you die"
Just very thankful I am up, around and able to work. It has now been three years since I took out that pesky deer. My own project "the camel" is more or less complete except for paint to body. Maybe when things cool off this fall I can get some paint on it.
83 GL in process :IDTS:
pidjones
#67
Post by pidjones »
Battery carrier (always an issue), lower tripple, and front upper motor mount panclened off with abrasive nylon rotary brushes mounted in the drill press. They await primer, but I had to order some (due in from Amazon in two days). Exhaust clamps cleaned up and sprayed with Rustoleum BBQ semi-gloss. Will probably start polishing valve covers and belt covers tomorrow.
pidjones
#68
Post by pidjones »
Washed and began removing a LOT of oxidation from the belt guards and valve covers for Pete. This will take days.
#69
Worth the effort but no so obvious now.
pidjones
#70
Post by pidjones »
Did a lot more painting of different things. Polished the left belt guard and 75% finished with the right guard. First rough go over the valve covers. Using a small cheap mototool with several Scotchbrite pads and several grades of nylon spiral polishing disks. Then 1200 and 7000 grit silicon carbide wet sanding finishing up with buffing wheel on the drill press with white and red jewelers rouge. The cheap (Harbor Freight) mototool is important because a regular mototool overpowers the little nylon disks.
#71
Good to know about the tool speed.
pidjones
#72
Post by pidjones »
More painting and polishing today. Started a valve cover. Tapped in head bearing races and assembled the steering stem. Primer and two coats of paint on the kick stand. If things go well, I should be mounting the frame on the engine by the end of the month.
#73
Nice to have a goal. We will be watching to make sure you hit the goal. Good progress so far.
pidjones
#74
Post by pidjones »
Finally able to post a photo, such as it is. Yesterday, my neighbor came over and helped to lift the engine from one dolly to the one with doubled 2x4s on it. This morning, I was able to mount the frame (loosely) to the engine. My philosophy is to make small amount of progress daily.
Rednaxs60
#75
Post by Rednaxs60 »
Looking good. Spyder in the background is nice as well, like the colour, mines the same.
Good philosophy on the work. Waiting until the eleventh hour, then scramble to get things done is not good.
Ernest
1985 GL1200 Limited Edition
2014 Can-Am Spyder RT LE
2008 GL1800 (sold)
