Popping out exhaust
Re: Popping out exhaust
#61
tory wrote: Sun May 05, 2024 7:48 pm Using MP08 coils and still point ignition.
Keep me posted on your success.
Take a little jumper of wire and run it directly from the neg battery terminal to the Condensor housing. See if that does anything
tory
#62
Post by tory »
Whiskerfish wrote: Sun May 05, 2024 8:03 pm
Whiskerfish wrote: Sun May 05, 2024 8:03 pm Take a little jumper of wire and run it directly from the neg battery terminal to the Condensor housing. See if that does anything
Good tip. I did replace the condensor last week and made sure all grounds where good and clean. Both condensors whete new but i had to try. There is a ground from the condensor direct to battery neg.
1978 GL1000
1986 GL1200 Aspencade
With California Sidecar
1965 CA95 Benly
tory
#63
Post by tory »
Happy to report the popping is gone. Maybe it felt threatened watching me tear down the old set of carbs. Lol
Or the cleaning last week had a delayed reaction 🤔
Could be the short rides every chance I get burning a fresh tank of fuel through.
Whatever the case, I started it to warm the boots before pulling the carburetors back off, and noticed it had not popped even after warmed up. I readjusted the low speed jet, and it actually made a noticeable difference this time. I did the idle drop as WF recommended and went for a 20 mile ride. Never ran better, no pops, much smoother through 4200 RPM and cylinder #1 was up to normal Temps.
1978 GL1000
1965 CA95 Benly
cfairweather
#64
Post by cfairweather »
Glad you got it solved. Now go for some long rides and enjoy it.
#65
Glad you got her out to the Holland Pier. That is what it takes to prove the problem is solved. Enjoy your ride.
#66
action1 action1 action1 action1 action1
Fingers crossed lolol lolol
redglbx
#67
Post by redglbx »
redglbx
#68
Post by redglbx »
So Tory, I realize that it’s been a year but what finally fixed your popping issue ?
Also I’d like to ask the group here if any of you have actually done the Mike Nixon suggestion of blocking the vacuum port off for the anti-backfire valve and what if any results you might have experienced ? I’m thinking of doing this on my 1100 carbs that are on my 76. Any inputs ?
