Wog's '78 Wild Child build
wog
Re: Wog's '78 Wild Child build
#676
Post by wog »
Planning on powering the chargers via belts from each side belt pulley.
Will make up somewhat "safe" covers for them.
If too much strain, change to running both from the center drive??
#677
“ Keeping it just a fun build crossy.gif” Ahh……yeah!
AMR also made a 300. 500’s should work with the right pulleys.
wog
#678
Post by wog »
Got a lot done on the top "manifold".
Just need to weld the end covers on and make the other side.
Also on the bottom, I'll add tabs for the other two mounting holes. Coulda got a little wider tubing, but I had this and I guess it's good to keep it as small as possible.
The pump rod hits the top and I was thinking I'd make a groove in the top center for space, but came up with just making 1/4" spacers for the clearance.
Pics don't show it but the holes line up correctly...
wog
#679
Post by wog »
ericheath wrote: Thu Jun 10, 2021 8:57 pm “ snip... 500’s should work with the right pulleys.
Eric, I ordered close to the same diameter pulleys for the drive that came on the charger. What's your thoughts?
5speed
#680
Post by 5speed »
wog wrote: Thu Jun 10, 2021 8:34 pm Planning on powering the chargers via belts from each side belt pulley.
could you run a single serpentine belt off the crank pully with 2 belt tensioners incorporated on either side of the crank pully?
#681
5speed wrote: Sat Jun 12, 2021 2:48 pm
I'd be more inclined to do something like this. It's been said there's too much play in the cam timing to begin with; adding a blower to the mix might be a nightmare...
wog
#682
Post by wog »
anim-cheers1 Thanks guys! anim-cheers1
I'll go that route.
This is why this is the best forum! :-D
wog
#683
Post by wog »
Another mock up...
wog
#684
Post by wog »
I had this lined up for the adv bike, but think I'll re-purpose it for this one.
Clearance for the belts, etc.
#685
Ha! Had that same thought...
#686
recommend removing the fork springs and check clearance to that Rad with the forks completely compressed. Couple of my Mods have run out of space in that area.
wog
#687
Post by wog »
Will do, thanks!
wog
#688
Post by wog »
For now, I'm planning on staying with a V-belt drive. May change to a serpentine later.
Received the drive pulley and cut off the extra thickness...
Looks like there's enough clearance to not have to replace the rad.
Also go with a cheap thin fan...
sgwilly
#689
Post by sgwilly »
Awwww, I want a metal lathe too.
What? Whining worked when I was six - sometimes.
It was worth a try.
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
wog
#690
Post by wog »
I played around with different style lower manifold ideas.
Started to bend the 1-1/2" tubing thinking I'd follow the last style but don't think I can get the tight radius's needed. Don't like the look of many welded sections.
Then thought about silicone radiator hose. Could be easily contoured to what I need but no rigidity.
So this is the plan (for now)...
Not sure about the internal adjustable damper but I think that might help getting more of an even amount to the rear intake.
...EDIT...
better update my extremely detailed drawing so I don't weld the mounting wrong :lol:
